I have been using DVD WS2 for quite a number of years now. I have always used the Wizard to make the menus. The drawback I have encountered is that backgrounds cannot be changed 100%. If I introduce a new background, the previous background shows through.
I thought I would try using "Create Menu - Blank" the first option. I have run into a problem here. I have a project that requires 7 chapters. Because there is a lot of text, I decided to go for 3 chapters per menu. (the last page has only 1 chapter).
I got them linked allright, BUT I can't get a consistent result when I want to highlight each thumbnail when a chapter is being selected. I went for color mapping so that a thumbnail could go red when selected.
Well, that works for the first menu, but does not carry through to the next menu(s). The next menu(s) default to a semi transparent white, which does not highlight the thumbnail very effectively.
I have tried copying and pasting the thumbnail attributes but that does not work either. Can anyone point me to the correct method of doing this PLEASE!
Thanks in advance,
Hans Gelton
New Zealand.
Highlighting thumbnails
Re: Highlighting thumbnails
I don't use Workshop anymore, but from what I remember each menu has to be color-mapped separately. You might even have to color-map each text-button separately. There's also a transparancy setting (under button attributes???) and I think you have to set that up separately for each button too.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Coral
- motherboard: Asus P8P67 Pro Rev. 3
- processor: Intel Core i5 2400 Quad Core 3.1GHz Socket 1155
- ram: 8 GB
- Video Card: Gainward GT 520 1024 MB RAM
- sound_card: On Board
- Hard_Drive_Capacity: 500 GB X2
- Monitor/Display Make & Model: AOC 19 inch CRT tube
I'm still using UDW2. Now more than ever since I have found a fast way of including subtitles.
I 'm not sure what you mean but you can set the transparency from: Menu > Button > Attributes. One of the options is Transparency.
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
If you want the same background and layout for each menu screen, then make your first one as you have done, set all the attributes, then save the menu.
Use this saved menu for menu 2 and highlight text and change.
Repeat for menu 3 and delete chapters you don't need.
