Thank you for Service Pack 4
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
http://www.corel.com/servlet/Satellite/ ... 9872271743
Any details about improvements... of overal stability?
Re: Thank you for Service Pack 4
Looks like all they done was added more RAW support, no bugs fixed..
Radim
- ram: 4GB
Yes, but there is a:Ron P. wrote:Looks like all they done was added more RAW support, no bugs fixed..
... Overall stability has also been improved. ...
on page SP4 - http://www.corel.com/servlet/Satellite/ ... 1240656342
kaymann
- motherboard: ASUS P8P67 PRO REV 3.1
- processor: Intel i-7 6800K
- ram: 32 GB
- Video Card: NVidia GeForce RTX 2060
- sound_card: Onboard
- Hard_Drive_Capacity: 3.5 T
- Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
- Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Do all four SP's have to be installed or just the lastest... The reason I ask is the file sizes, if they were inclusive installs the files sizes should be getting bigger not smaller.
PaintShop Photo Pro X3 Service Pack 4 11.1 MB
PaintShop Photo Pro X3 Service Pack 3 42.7 MB
PaintShop Photo Pro X3 Service Pack 2 46.5 MB
PaintShop Photo Pro X3 Service Pack 1 10.5 MB
Radim
- ram: 4GB
The latest PSPP X3 Ultimate (TRIAL) - at http://www.corel.com/servlet/Satellite/ ... bview=tab7
allready have SP1 and SP2 integrated. You need *only* SP4 ...if you use an EN lang.
The others SP1-SP3 has all langs inside, therefore SP is so big. ...so I believe that Corel use cumulative Service Pack method.
Corel has released 4 versions in 2010 so it depends on what release (install EXE) you have.
nitroman84
- motherboard: oem toshiba
- processor: 2.0GHz
- ram: 4GB
- Video Card: ATI RADEON MOBILITY 4100
- sound_card: REALTEK
- Hard_Drive_Capacity: 3TB
I've only tested for a short while, but for me SP4 makes a world of improvement in stability. Might even say I'm proud of Corel for fixing it, thought all hope had been lost.
kaymann
- ram: 32 GB
What is the version number of PSP with SP 4 installed?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
13.1.2.20
And the stability has been improved. The DNR problem, for me at least, is fixed but that is expected as it says that it fixed the stability when working on duplicate/multiple layers especially with noise removal, scratch removal, and skin smoothing.
It also says that it fixes the stability of the scratch remover tool.
bigfatron
- motherboard: Gigabyte Z87 D3HP
- processor: Intel Core i5 4670K
- Video Card: Nvidia GTX680
- Hard_Drive_Capacity: 5TB
- Monitor/Display Make & Model: Dell U2412M & Dell 2007FP
Still no fix for the memory leak issue I raised quite a while ago though
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Did you try the solution I gave you on the thread that you started?bigfatron wrote:Still no fix for the memory leak issue I raised quite a while ago though
Regards, Dan
bigfatron
I must've missed your post the first time around but have now had a look. Yes after a very quick and dirty test it seems to help, although I'd much rather Corel get around to fixing what is quite a fundamental problem and one that they've acknowledged as a bug in the program.df wrote:Did you try the solution I gave you on the thread that you started?bigfatron wrote:Still no fix for the memory leak issue I raised quite a while ago though
geru
- processor: AMD Phenom II X6 1065T Processor 2.9 Ghz
- ram: 8 GB
- Video Card: AMD Radeon HD 6850
- sound_card: AMD High Def Device
With all 4 Service Packs it is version 13.2.1.20LeviFiction wrote:13.1.2.20
Does anyone else find the DCNR, skin softener tool, and USM seem to work faster? I ran the DCNR twice because I didn't see the tool rendering and when I watched the second time it rendered very quickly.
kaymann
- ram: 32 GB
Interesting mine reads:
13.2.0.41
What's up with that? Anybody recognize this one?
When I try to apply patch 4 I get the following message:
"No update of your installed software is required at this time"
13.2.0.41
jukka
- System_Drive: B
- processor: thunderbolt
- ram: 32bmw
- Video Card: s3 triodent
- Monitor/Display Make & Model: whaat?! 4 monitors. Yup! 4
- Corel programs: psp 2020, videostudio 2019
It's not nice to notice that not one of the improvements that I have suggested came with this update.
-HDR merge image selector cannot remember it's last folder. No drag and drop. No load via selecting images from organiser
-Organiser does not remember scroll position when using express lab or the selected images
- many more
but lets hope this takes couple of crashes away. It has already improved from earlier versions.
But either way i remember that corel would have had some kind of video editing tool. Does it still exists or can some other corel software also used for cutting & editing videos ?
- many more
Yes Corel does have Video editing software:
http://www.corel.com/servlet/Satellite/ ... bview=tab0
