VCD Pal Format - small Screen
bajodi
Post by bajodi »
:roll: I rendered a AVI raw file for the following :
PAL VCD,
352 x 288 (this is the problem) It does not allow to make big screen
aspect ratio : 4:3
24 Bits, 25FPS
Edit format : MPEG
After completion when I play in Window Media Player or RealPlayer the movie size is very small no matter if I make a big screen.
Does somebody can redress this problem or any alternative. By the way if u suggest me to make DVD then I do not have DVD player and I want it to be in VCD Format.
kebrinton
Post by kebrinton »
So, you want it to be VCD format but you're viewing it with RealPlayer?
How does it appear when you burn a VCD?
llama
Post by llama »
There is not way to make the resolution of a VCD higher than 352x288. If you want higher resolution, you will have to go to DVD.
THoff
Post by THoff »
In Windows Media Player, under Tools -> Options, go to the Performance tab, then click Advanced, and move the Digital Video slider all the way to the right.
