Hi all
Have just bought boxed version VSx3 and unable to get to use!! every time that it says install finished i click corel VS icon on desktop and my pc reboots have tried 4 removals with the corel clean utility and registry edit removal of keys to no avail. Any help would be appreciated. thanks in advance.
install problem
vistaflix
- motherboard: Packard Bell BV MCP73VT-PM 1.0
- processor: 1.80 gigahertz Intel Pentium Dual 64 kilobyte prim
- ram: 1792 Megab
- Video Card: NVIDIA GeForce 7050 NVIDIA nForce 610i
- Hard_Drive_Capacity: 1875 gb
Re: install problem
Welcome to the forums,
Where did you purchase it? Did you install it to the default drive, ie; C:\ Program Files ? Did you run the installer as Administrator? If not try doing so by right-clicking on it and selecting that from the menu. Also try disabling UAC (User Account Control) while you install it. The fastest way to do that is Start>Run, the type in msconfig. In the configuration utility go to the Tools tab, scroll down and select Disable UAC, then press Launch. You may need to reboot your system, or at least log-off then back on.
After trying the above and it still doesn't work, I'd be running a virus scan.
vistaflix
- ram: 1792 Megab
Re: install problem
Hi and thanks for your prompt response will do all you suggest now!! as pulling what hair i have left out....
vistaflix
- ram: 1792 Megab
Re: install problem
Hi again
UK Mail order reputable supplier
Yes
Yes
Tried still reboots pc on clicking CorelVS3 icon
Run Iobit Mcfee and avg all clear they state
No problems with any other software as known
HELP
Yes
Yes
HELP
