ULead moviefactory 5 Text shrinks on burning DVD
elbecar40
ram: 512
Post by elbecar40 »
I have made a few DVD slideshows using ULead DVD moviefactory 5.0 and after having it all looking how I want it, I burn to DVD, then play the DVD and the text has shrunk and moved on all the portrait photos, sometime across faces etc. while the landscape photos stay how I want them. How can this be fixed? Any suggestions would be appreciated. Thanks, Leonie
Re: ULead moviefactory 5 Text shrinks on burning DVD
Welcome to the forums,
First thing that comes to mind is what size of television are you viewing your DVD on? If you have a larger wide-screen TV, things will appear smaller than what you see on your monitor, unless you have a large PC monitor.
Did you save your project? Go back and check to see if somehow the text was moved or re-sized. What size font are you using? If everything appears to be ok, try burning to your hard drive. To do this uncheck the box beside the Create to Disc, and check the one beside Create DVD Folders. If you do not see the Create DVD Folders, click on the double downward facing arrows button on the Right side. When you Create DVD Folders, you will be able to do a final check to make sure everything came out the way it should have, using a software player, most are capable of playing DVDs. The only difference between burning to disc and folders, is the media used. One uses a disc the other your hard drive. If everything turns out fine with your folders, then just burn the folders to a disc.
