I have applied a reflection to my PIP, which has an opacity of 20%, an offset of 2% and a fade of 75%. However, these settings are only correctly applied in the PIP preview window. In the main timeline preview window, the opacity and fade are at maximum strength. Only the offset is what it should be.
Your help would be most appreciated.
Many thanks.
VS X3 Picture in picture error
catalyst99
- motherboard: Gigabyte
- processor: Intel 4 3.4 Ghz
- ram: 1GB
- Video Card: Intel Graphics
- sound_card: Intergrated
- Hard_Drive_Capacity: 30GB
Re: VS X3 Picture in picture error
In just about all the preset FX they use keyframes to show you how an effect can change over time. The NewBlue presets are always set on a center keyframe. Make sure your settings are the same at the beginning and ending keyframes to make your effect consistent, if that is what you are looking to do.
Jeff
Dentler's Dog Training, LLC
tinybeetle
- motherboard: Gigabyte GA-870A-UD3 - AMD 870 w 2x PCI-E 2.0 x1
- processor: AMD Phenom II X4 965 Black Edition Quad-Core CPU
- Video Card: NVIDIA GeForce GTS 450 - 1GB
- sound_card: 3D Premium Surround Sound Onboard
- Hard_Drive_Capacity: 1.03TB
The timeline may not accurately reflect the effect until you have rendered the video. Some effects take a lot of processor power. Once rendered then the smart proxy should have a reasonable representation of the effect cached.
Jan Broucinek, MOTO, UG, DP
Exactly the reason why they shouldn't have done away with the High Quality Preview. Don't get me started...tinybeetle wrote:The timeline may not accurately reflect the effect until you have rendered the video. Some effects take a lot of processor power. Once rendered then the smart proxy should have a reasonable representation of the effect cached.
Jeff
catalyst99
- ram: 1GB
Thanks for your replies. I doubled checked my keyframes and they were correct. Unfortunately, the main timeline preview remained the same and it rendered the same result. Can't understand it.
Have you manually updated Direct X?
Although we have Windows Auto Updates the manual install of Direct X has been known to cure some strange problems with Video Studio.
There is a post at the top of this forum with a link to the Direct X web site.
http://forum.corel.com/EN/viewtopic.php?f=1&t=36002
From the direct x site search for "direct x redist" use the latest version, I found-- DirectX Redist (June 2010)
It’s a three part process, Download, run exe file to Extract files, run DXSETUP.exe from extracted files.
This may not cure your problem, but its worth doing, just in case.
