Copy Protection?
Ray Musicbear
Copy Protection?
Post by Ray Musicbear »
Is there a way that UVS9 will add, "copy protection" to my DVD, so that it cannot be copied by others?
If so, will this effect the compatability of my DVD's with standard players?
Thanks for any replies.
GeorgeW
Post by GeorgeW »
UVS9 doesn't have that ability.
DVD WS 2.0 (Full) has the ability to add copyprotection flags -- but they are intended to be turned "on" by the software, and you will have to send your DVD out on DLT to be "replicated" by a replicator.
You won't be able to just burn them to a DVD±R/RW Disc using a DVD Burner.
George
keenart
Post by keenart »
As an Artist and one who has tried Copy Protection, Watermarks, Encoding, and other methods, I can tell you if you can Protect it, THEY CAN BREAK IT!
All of my work is protected under US Copyright Protection, I have tons of applications. It really makes little difference if someone wants to steal it. The Music industry is using spy bots, and Trackers placed into the Headers of the Music. Artist are Encoding works of Art with their DNA, the attempts are extreme. In every case someone finds a way to break the Protection Scheme.
What the HELL is wrong with Humanity that I work so hard to create something so beautiful as another Lazy SOB would steal and take credit. AND, some have the audacity to call it Flattery!!
Ulead uses the Digimarc Plug-in as standard for Images, and this feature is not cheap to record your protection efforts. If you have sent a Copy and Registered with the US Gov. you are protected if it comes down to a Law suite, the same for Digimarc.
Otherwise you will have to have the Disc sent to a Company that will Protect the Disc for you and that is very expensive, as they have to duplicate all of the discs for you, because the Disc can not be copied by you.
Basically what you are trying to do is record you work in advance of release to the Public, creating as many legitimate sources as possible to protect your right to sue against copyright infringement. Meaning, using these companies and documents as ample evidence “said” work is your work.
There you have it. DEPRESSING ISN’T IT!!
DVDDoug
Moderator
Post by DVDDoug »
The tools to remove Macrovision and CSS are free! (And, apparently illegal in the USA.)
Besides the license cost, CSS cannot be used on a "burned" DVD do to technical limitations / specifications. This means that it's technically impossible to make an exact bit-for-bit copy of a comercially-stamped CSS-protected DVD... which of course would play just like the original... defeating the whole purpose!
I think you can activate the macrovision bit on a burned DVD, if you have the software and expensive license.
There is also something called CPRM which can be used on burned DVDs. It's supposed to be better than CSS. I have no clue where you get the software or what the costs are.
All currently sold DVD players are supposed to play Macrovision, CSS and CRPM encoded DVDs.
The licensor of CSS encryption technology is DVD CCA (Copy Control Association), a non-profit trade association with offices at 225 B Cochrane Circle, Morgan Hill, CA. There is a $15,000 annual licensing fee, but no per-product royalties. Send license requests to css-license@lmicp.com , technical info requests to css-info@lmicp.com . Before December 15, 1999, CSS licensing was administered on an interim basis by Matsushita.
Macrovision licenses its analog anti-recording technology to hardware makers. There is a $30,000 initial charge, with a $15,000 yearly renewal fee. The fees support certification of players to ensure widest compatibility with televisions. There are no royalty charges for player manufacturers. Macrovision charges a royalty to content publishers (approximately 4 to 10 cents per disc, compared to 2 to 5 cents for a VHS tape).
If you have your DVDs produced in quantity by a replicator, they will already have a liscense, and there will only be a small per-disc charge.
keenart
Post by keenart »
Microsoft uses Macrovision, you can find a Tmp file on the drive every-once-in-awhile.
A little off the subject, friend and classical Guitar player tells me; when I record my tracts I create an overlay. It has a high or low frequency and appears as noise on the disc, but is not heard when played. It contains my name copyright info and is repeated every 30 seconds. Even if they copy it, I got them. No, I am not giving you anymore details than that.
End of interview.
kebrinton
Post by kebrinton »
Last year, working with VS8, I discovered that a video I'd created of a family member performing, was copy-protected. I tried to make copies to send to relatives, but Nero wouldn't let me: Copy Protected!
I bet a lot of people would like to know how to do this. So would I. In that circumstance, I had to go back and make a new DVD, which amazingly was NOT copy-protected. So the relatives got their copies.
keenart
Post by keenart »
It ain't cheap, does encryption, Workshop Express does not.
Ulead DVD Workshop 2 is powerful and intuitive authoring software for professional DVD creation. The straightforward workflow and design-centric interface guides you through the steps needed to create dynamic DVDs. It offers sophisticated tools for complex menu navigation, multiple subtitles, and multiple audio tracks with support for Dolby Digital AC-3. DVD Workshop 2 guarantees creative professionals a maximum return on investment, with a minimal learning curve.
DVD Authoring Software for the Creative Professional!
Create dynamic, custom motion menus
Image and video blending (compositing) in menus
Control audio, subtitles and video sequences through the Playlist
Import images including layered PhotoImpact & PhotoShop files
Multiple audio and subtitle streams
Dolby Digital Surround input and Stereo encoding
Two-pass MPEG-2 encoding for higher quality DVD productions
DVD-9 dual-layer DVD recording
Macrovision, CSS encryption
THoff
Post by THoff »
kebrinton wrote:Last year, working with VS8, I discovered that a video I'd created of a family member performing, was copy-protected. I tried to make copies to send to relatives, but Nero wouldn't let me: Copy Protected!
That likely was a bug in Nero, where it misinterpreted some other condition as Macrovision or CSS protection -- UVS simply doesn't support any of these features during its disk creation process.
