But there are some problems with that,as I have discovered.
I am using a program for some pre-editing,and it can only output to WMV. When I want to insert one
of these clips I get the following message: "The file xxx.WMV cannot be edited.Do you want to perform
pre-process to make it editable?" I click yes,and it goes through this,whatever it is,and the clip
shows up in the library.
The curious thing however is that it only works with one file at a time. I have to close the program and
open it again to be able to insert the next .wmv file, and so on for every clip. A bit boring to do it like this,
but luckily I usually work with fairly short projects.
I discovered though that after the proxyfiles have been created,the .wmv files can be inserted without
problem,but then I've not much use for it.
Another problem with these .wmv files is that the audio is missing, I don't know why. I should write to the
people who created the program I suppose.
I have to extract the audio from my original m2ts files,and put them in the editor and combine video and
audio that way.
But there are still more problems. Replay in the projekt is often jerky and stops, wich I suspect has to do
with the proxyfiles. They might not work as they should with .wmv files, or it could be something with these
special files I am using.
According to the info I have they are: Windows Media Video 9,Advanced Profile.
And I have to say that after all the trouble,I can render them to AVCHD,
they play well and no problem with transitions. Perhaps support here have any ideas about this?
By the way,glad to read that someone had used VS pro in Windows 7,and that it worked well.
I am going to upgrade to 7 from XP, it feels a bit daunting,and means a lot of work.
I think I better finish my editing in XP first,and be very careful with backup.
Leif G.
