Magic Wand
auggybendoggy
motherboard: asus pne5 SLI
processor: Q6600
ram: 4 gb
Video Card: 9800 GT nvidiia
sound_card: M-audio 2496 audiophile
Hard_Drive_Capacity: 350 gb
Magic Wand
Post by auggybendoggy »
Do I need to do a blood sacrifice in order to make the magic wand remove selection work? I've tried about everything and it simply does nothing. The only thing I can think of is perhaps Corel has designed the software so that I have to take a lamb without defect and put it's blood on the my door frame. Then perhaps in the morning the mask will be complete????
Any help would be appeciateated.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Magic Wand
Post by LeviFiction »
You, need to develop a sense of humor. You also need to tell us what you're doing to try and remove part of a selection because I have no problems with the magic wand tool so I have no idea what you're talking about.
Though, honestly I don't use the magic wand tool. Too imprecise for my tastes.
First of all you need to be selecting inside of a current selection to remove part of it with the magic wand tool. Secondly you need to have it set to Remove or be holding Ctrl when you click on the area you want to remove from the selection. The mode you're using is also important. Does your image have multiple layers? If so are you telling it to select using all layers? If not does the layer you're clicking on actually have the area you want to remove from the selection?
Is the area not selected? It's sometimes hard to tell. That's nothing against you, that's against the marching ants. One way to tell for sure is to ho up to the menu and go Selections->Edit Selection the area that turns red is selected. Everything else is not selected.
There's also the possibility that you're talking about a single area not being deselected when you click on a similar color on the other side of the image. In which case do you have "contiguous" turned on or off? Contiguous means that the pixels are directly connected in some way to each other. Discontiguous would mean that it doesn't care where in the image it matches the pixel you clicked on it'll find it.
Tolerance could be too low.
It could be anything. Give us something to go off of, please.
jaxman43
motherboard: PEGATRON CORPORATION 2AC2 2.00
processor: 3.40 gigahertz Intel Core i7-2600
ram: 8 GB
Video Card: NVIDIA GeForce GT 520
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: HP 2311
Re: Magic Wand
Post by jaxman43 »
@LeviFiction - If you don't use the magic wand, how do you do your selections?
Larry
pdxrjt
processor: Intel Core i7 - 4.2 GHz
ram: 32 GB
Video Card: NVIDIA GeForce GTX 1080
Hard_Drive_Capacity: 10TB Int.
Monitor/Display Make & Model: Acer 32 inch x2
Corel programs: Paint Shop Pro 2018
Re: Magic Wand
Post by pdxrjt »
LeviFiction wrote:You, need to develop a sense of humor. You also need to tell us what you're doing to try and remove part of a selection because I have no problems with the magic wand tool so I have no idea what you're talking about.
Just what I was thinking. I don't have problems with magic wand....but like LeviFiction, I don't use it often.
Adverts for Corel products when you close PSP don't bother me.
ram: 6 GB
Re: Magic Wand
Jaxman, since I tend to be selecting people or specific objects from complicated backgrounds I either use vectors, the point to point lasso selection tool, or journeyman masking if necessary. They take longer, sometimes needing more refining. But I have that control. Something the wand doesn't give me. Not saying it's not useful, I'm just never in a position where that use is an actual advantage over the other methods.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: Magic Wand
Post by teknisyan »
Hello auggybendoggy,
You may want to try reset the workspace by holding down the SHIFT key then double-click on the Paintshop Pro icon, when you received the message below, just click on OK button.
Reset PSPX3.jpg (24.04 KiB) Viewed 4962 times
You may also want to download all the updates by clicking on HELP menu then select CHECK FOR UPDATES..., or download the updates from http://www.corel.com/servlet/Satellite/ ... 9872271743.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
