How to import from a Sony HDR CX550V?
daddog
Post by daddog »
I had to reformat my HD and have to go though the process of importing videos to X3.
I recall some 'steps' involved, but am at a loss. Was there another program I am to use to import into X3?
Jeeze, this should be easy.
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
Re: How to import from a Sony HDR CX550V?
I thought it *was* easy... You either connect the camcorder to your computer via USB cable and simply Copy/Paste to a folder on your PC using Windows; or take out the flash drive and put it in a flash card reader and do the same. I even thought you could simply open X3, using 'Insert Media File" and navigate to your camera flash drive. It is, after all, regarded by the computer as just being another external drive...
I also thought Sony provided some basic software with the camera which would allow you to transfer the video to your PC. In the process, I think the original .mts format gets slightly changed (though not converted) to .m2ts format... But X3 can handle either.
snowstorm
motherboard: ACPI x64 Based PC
processor: AMD RYZEN 5 1600 Six Core
Video Card: RADEON RX560
sound_card: REALTEK HIGH DEFINITION AUDIO
Hard_Drive_Capacity: 2 Tetra
Monitor/Display Make & Model: Samsung SyncMaster 2494HM
Corel programs: VS2021,VS2018,VSX9,VSX8,VSX6
Post by snowstorm »
If this could help
I shoot my clips with a Sony HDR-CX520V (many times on Memory Stick Pro-HG Duo)
I copy/paste my clips onto my PC to a dedicated folder with a USB cable through Windows Explorer
Always do perfect job.
Create MTS files
Happy New Year
snowstorm
pyvo
Post by pyvo »
I confirm Ken's statement above;
For the same camera, I
- installed the Sony soft called Picture Motion Browser (PMB) supplied with the camera (or downloadable from Sony site)
- used PMB to capture the .m2ts files onto HDD and then
- imported these files for edit using VS X2.
The process works fine even if it is a little slow on my laptop (Centrino 2, 2.26GHz, Win Vista, 4Gb DDR2 + plenty HDD).
When capture is complete, disconnect the USB link from the camera menu first (before physically unplugging) - no need to use Windows option 'Safely Remove Hardware' option.
daddog
Post by daddog »
Thanks Gents,
What I 'forgot' was to install the Sony software. That was the missing step. :)
I appreciate the replies. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
