Movie Factory 2.5SE - AVID exported QT Ref files to DVD
mwight
Post by mwight »
I need help. I am attempting to burn 7 AVID exported QT reference files to DVD-R. My PC is a HPxw8000 Workstation with a 2.8GHz CPU and 2GB RAM. The running time for all 7 files is 3hrs 3 minutes. MF said, and I know it isn't always accurate at this, that I needed 4.0 GB of space. Could the problem be that the actual space needed onthe DVD is over the allowable 4.3GB? I know this will take a long time to burn, but ULEAD worked for over 12 hours and then gave me an error "Unspecified Error". Should I burn them one at a time, should I export my AVID files in AVI instead of QT? Is there something else I could do?
GeorgeW
Post by GeorgeW »
check the temp folders for your converted videos -- they might be in there, and you can re-use any that were successfully converted (instead of re-encoding from scratch). I think they start with the "~" symbol.
were you trying to burn to hard drive (DVD FOlders and/or DVD Image), or were you burning to disc? I would burn the DVD FOlders to HD, then in a separate step burn from HD to disc.
George
mwight
Post by mwight »
George W.
I'll check for the already converted files. If they are there it will definitely help. Thanks. (I've been producing government videos for 25 years, but I'm a newbie in DVD burning!) I was attempting to burn to disk. I'll try burning the folders to HD and from HD to disk. Thanks much for the suggestions.
