Unable to uninstall VideoStudio
qim
Post by qim »
I cannot uninstall Ulead Videostudio se DVD. I want to reinstall as there are problems with the programme. As soon as I try to unisnstall from Add/Remove progs a box comes up saying that InstallShield (R) Setup Launcher has encountered a problem and needs to close. etc...
Help!
Thank you
qim
Re: Unable to uninstall VideoStudio
Post by BrianCee »
Hello and welcome
Unfortunately you didn't tell us which version number of VideoStudio SE DVD you are using.
This procedure is for version 11 :-
http://corel.custhelp.com/app/answers/d ... 3/r_id/166
but you may be able to adapt it by changing numbers for the appropriate files - failing that post a version number and there may be a knowledge base article for it
qim
Post by qim »
Sorry...
8.0 SE DVD
qim
Post by BrianCee »
I can't find a procedure for version 8 - I don't think there is anything that old on there - I did find this for version 9 :-
it may work if you just change the 9's to 8 in the procedure all the file and folder positions were the same in those earlier versions.
Post by Trevor Andrew »
I found some very old info regarding VS 8.
Maybe the folder/files shown in 2 and 5 are relevant to VS8.
1) Clean up C:\Windows\temp directory.
Uninstall anything to do with VS 8.
Clean up all files in C:\Documents and Settings\[UserName]\Local Settings\Temp folder.
Uninstall VideoStudio 8 using Control Panel Add/Remove programs.
2) Delete folder {4F1DA6BF-3614-48A1-9970-9E90F646789E} in C:\Program Files\InstallShield Installation Information
(Make sure you set "Show hidden files and folders" in folder option in OS)
3) Delete the folder "Ulead VideoStudio 8.0" folder in C:\Program Files\Ulead System
4) Run Regedit from Start/Run in Windows task bar
5) Delete folder {4F1DA6BF-3614-48A1-9970-9E90F646789E} in
KEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
6) Then reinstall program and any patches.
Hope this Helps
Ps
You could try installing VS 8 and choosing the repair option, just maybe that will correct the corrupt install shield.
qim
Post by qim »
Thank you, all
I managed to clean up, install and uninstall as I wanted. Then, I reinstalled but unfortunately the problem that I had originally continues. I have an icon ( avideo file, I suppose) in the Ulead desktop that I cannot get rid of. It has a X from corners to corners, seems to have a name of an old file. When I try to open it it says the original does not exist, but If I try to delete it, the programme crashes. I have deleted all the files that I could find where this ghost file could be, but it stays there even after reinstalling.
Any ideas?
Thank you and a happy new year!
qim
Can you explain a little further.
Is it in the VS8 library.?
When you re-installed VS did the library revert to the default state or do you see some of your clips.
Can you post an image?
Re: Unable to uninstall VideoStudio 8
Something to try
Shut down VS8
Are you able to find this folder:-
C:\Documents and Settings\User Name\Application Data\Ulead Systems\Ulead VideoStudio
If so re-name the 8.0 folder to “8.0copy”
Re start VS8
Did that make any difference.
Edited
If you do not see the folder go to
Tools-Folder Options-View—select Show Hidden Files and Folders.
qim
Post by qim »
Great. It seems to have worked.
I say, seemed, because I did not have a 8.00 folder but a 10.0 folder, probably left over from an aborted install of the 10.00 version. However, after opening the prog again it created anew 10.0 folder (even though my prog is 8.0) !!!
qim
Hi qim
Wow, are you sure???????????
Click the small question mark..?.. top right of screen and select About Ulead Video Studio.
What does it say?
Whatever, if you have managed to get the program working then that’s all that matters.
qim
Post by qim »
Hi Trevor.
Sorry for the delay. I thought I always got an email advising of a new post. Well, aparently I have Version 10, even if the disc and accompanying literature said 8.0
I guess all is well, then.
many thenks and a happy new year.
qim
