I have a project that suddenly won't load. I have 25 versions of it, I save it under a new file name each time in case I need to go back to an older version.
trouble is most of the versions won't load! Only the very early versions will load. Some of the later version start to load then disappear.
Anyone else had this type of trouble?
Hardware hasn't changed on the PC, maybe the video drivers have been updated, thats about it.
Any ideas please? hours and hours of work omg.
VSx3 won't load projects that would load before
Re: VSx3 won't load projects that would load before
Problem solved, it seems I'm an idiot, I was trying to load x3 project files with version x2. Seems it's not compatible.
If you're an idiot, we all are..
.. Not hard to open the wrong program when you have a couple installed. Then to top it off, the icons for VS X2 and X3 look the same.
In the general sense, no they are not compatible. However you can save a VS X3 project as a VS X2 or VS 11. The caveat being if you're using any effects that the earlier versions do not have, those effects will disappear.
