How Do I Fade Out A Audio Clip Completely
Tony S
motherboard: Dell Inc. 0M017G A00
processor: 2.67 gigahertz Intel Core2 Quad Q9400
ram: 8192 Megab
Video Card: ATI Radeon HD 3650 [Display adapter]
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 1000.14 Gi
Post by Tony S »
I hope everyone here is having a excellent holiday season. The reason that I am here today is to see if someone could give me a little advice on how to fade the volume out completely at the end of a audio clip. I have read the manual on the subject and have tried to follow the instructions that it gives. Until now I have not had any success. I know that I am missing something I just don't know what it is. I would like the audio to fade out completely so that I can fade in to another audio clip. I have clicked the fade out tabs but the volume only decreases a little at the end of the clip. Can someone help? :(
Thanks,
Tony S.
Re: How Do I Fade Out A Audio Clip Completely
Post by Trevor Andrew »
Hi Tony
From Preferences you can change the audio Fade durations.
They default as 1 second, I usually set to 3 seconds
There are fade ramps adjacent to the digital clock as image below
Caimen1
motherboard: ASUTeK Computer Inc CG5270
processor: 2.50 gigahertz Intel Core 2 Quad Q8300
Video Card: Intel G45-G43 Express Chipset
sound_card: Intel High Defination Audio HDMI
Hard_Drive_Capacity: 1 TB
Post by Caimen1 »
Tony,
Thought I'd mention this because it took a while for me to figure this out...
If you've changed the volume either in options or by dragging the rubber band in the Sound Mixer then I don't believe you can get a smooth fade-out.
I know I couldn't. Reset the volume to "100" and you should get a complete fade without an abrupt ending.
Tony S
ram: 8192 Megab
Post by Tony S »
Thank you Ron & Trevor as usual you guys have came to my aid and help me understand in a easy fashion how to use a function in VS. I want you to know that it is really appreciated.
Gratefully
Tony S. :)
Post by Black Lab »
I have also found the problem that Caimen1 describes, that once you change the volume screwy things happen. However, if you change the volume back to 100, then apply your fade, then re-adjust your volume, all the changes stick. In other words, make all your fade adjustments before you adjust the volume.
Jeff,
Does the screwy things show in the wave-form/rubber-band? Or is it just happening behind the scenes?
Tony S wrote:Thank you Ron & Trevor as usual you guys have came to my aid and help me understand in a easy fashion how to use a function in VS. I want you to know that it is really appreciated.
Gratefully
Tony S. :)
Thank you for the compliment Tony. It's much appreciated!!
Merry Christmas.
Post by Black Lab »
No, the wave form will show it fading out, but it doesn't fade all the way, as Tony and Caimen1 have described. Or sometimes if I create a longer fade it will revert back to the default fade.
david1939
motherboard: Unknown
Hard_Drive_Capacity: 465GB
Corel programs: VS ultimate 2023,MotionStudio 3D
Post by david1939 »
I can confirm what you are finding -- I battled some while ago with trying to get a fade to zero on a clip and discovered it doesn't work if you have raised the overall volume level well above 100. The rubber band display shows the fade is there, but the maximum diminution it can apply is not enough if the basis volume has been boosted, and so the sound stops suddenly. Just wondering: if you cut the clip which has a set volume >>100, a little before the end, set the volume to 100 for the second clipped portion and fade that out; also, fade out the first clipped portion, with a little experimentation you might be able to get a smooth fade and keep the enhanced volume level for most of the scene.
SONY DCR-HC42 Handycam, VideoStudio X4 Pro, X5 Pro, X6 Pro, Motion Studio 3D
