Prev and Next buttons not showing in Create DVD wizard
Simon
ram: 4gb
Hard_Drive_Capacity: 320GB
Post by Simon »
Using Ulead Video Studio 10.0.0110 0 SE DVD
Using this tool I wish to create a DVD with a stored project file(vsp). using the Studio Editor/tools/CreateDisc option. I then have problems with subsequent screens because the Previous/Next buttons do not display as per the documentation. Therefore I am unable to go backwards and forwards throught the wizard steps. I have attached screenshots.
I am running Window 7 64 bit Home premium. In other ways the software appears to work fine.
In an attempt to resolve the problem I have attempted to run the service pack 1 dated 2007-01-15. However this refuses to run stating that Video Studio is not installed.
Any help would be very much appreciated
Ulead screenshot 2.gif (172.24 KiB) Viewed 351 times
Re: Prev and Next buttons not showing in Create DVD wizard
Post by BrianCee »
Hello and welcome to the forums.
Bad news I'm afraid - the problem is due to the fact that VideoStudio 10 is not compatible with Windows 7 - VS10 was released long before Windows 7 was released and the combination cannot be made to work
You have some options - I would suggest the first is to create a DVD compliant mpeg file in VS10 and then use one of the many free DVD burning programmes around to actually burn your disc, If you want a more elaborate DVD structure you may like to buy a dvd burning programme like Roxio for instance - if you are in the USA I think you will have access to buy Corel DVD MovieFactory 7 to burn discs but that does not seem to be available every where in the world.
Another option would be to upgrade to VideoStudio X3 - that in itself cannot burn a DVD but it does give you free access to DVD MovieFactory 7SE wherever you are in the world.
In the meantime, while you decide what to do, you could try using Ctrl + N to move to the Next page and Ctrl + P to move to the Previous page...
Post by Trevor Andrew »
From memory and mines not that good of late, but it may well be Alt + N and Alt + B
I don’t have Video Studio available to check at the moment
Mine's definitely no good. Have now checked and found you are right, Trevor.
Simon
ram: 4gb
Post by Simon »
Many thanks. the alt key trick worked nicely
