save as still image distorted
dmz
motherboard: ASUS ROG Strix Z390-I
processor: Intel Gen 9 i7 9700K
ram: 32GB
Video Card: mobo onboard
sound_card: mobo onboard
Hard_Drive_Capacity: 6TB
Corel programs: VS 2020
Post by dmz »
Greetings,
I have a 16:9 video and when I select "save as still image", the resultant image is squeezed into 4:3 and doesnt look good. I cant see anything in preferences that allows me to adjust this. Can I tweak "save as still image" so it keeps the correct aspect ratio?
David
dmz
ram: 32GB
Re: save as still image distorted
Post by dmz »
I found it. I have to use project instead of clip and select tools > save as still image.
Post by Trevor Andrew »
Hi David
When you save an image in clip mode the image uses the video frame size.
When you save in project playback the image uses the project size and aspect ratio.
It produces an image as you see it in the preview screen.
For Pal the 16:9 image will be 1024 x 576, and that’s 16:9 ratio.
