Hello,
Since my main menu include only one movie, is it possible to skip the main menu, so the submenu with the selected chapters will become the only one menu?
Thanks,
Abraham
skipping main menu in vs pro x3
Re: skipping main menu in vs pro x3
Which programme are you using to make your DVD menu - is it Movie Factory 7 SE or DVD Factory "Pro" 2010.
Yes, the option to hide/skip the main menu can normally be found under an Advanced button as Create Main Menu, deselect this option.
You can only hide the main menu if it contains a single video/title. More than one title and you have to use the main menu.
The exact location of this option depends on the program being used, although I don’t know Pro2010
That is why Brian asked what authoring program he is using. Factory Pro cannot hide menus.
Jeff
Dentler's Dog Training, LLC
zehavi
- processor: Intel[R] Core[TM] i7-8700 CPU 3.20 GHz
- Hard_Drive_Capacity: 465 GB
- Monitor/Display Make & Model: LG
Thank you all for your answers,
Actually I am using the VS10+ to create the DVD disk. I am using the VS pro x3 to capture and edit the movie. Sorry for the incorrect title of my post. I am doing it because with VS10 I am able to slow down the burning speed, and in this program I didn't find the option to skip the main menu.
From your answers I understand that only with Movie Factory 7 SE I am able to skip the main menu. Is it correct?
Thanks again,
Abraham
Thanks again,
Abraham
You can disable the main menu using VS 10
From the Edit Tab select the Advanced button--uncheck "add title menu"
zehavi
Thank you Trevor,
So simple.
Abraham
So simple.
Abraham
