Download Files???
mariealline
Download Files???
Post by mariealline »
Where are the PI versions 7 & 8? I can't find them to download anymore and my upgrades will not install without at least PI 8 full version. I have my serial number for that and it's a full version but I can't find it to download.
Thanks in advance,
Marie
keenart
Post by keenart »
Go here and read carefully, you will be given the options you request:
http://www.ulead.com/tech/faq/custservice_faq.htm
mariealline
I am sorry! I already found the answer. I had ordered the cd but I didn't remember because I have bought every upgrade so far since the original version that I bought. Anyway, can I uninstall the previous versions once I have the current version installed? I certainly don't need 4 different versions on my computer.
Thank you,
Marie
keenart
Post by keenart »
If you have all of your previous versions installed, that might be a problem. However, before you do anything consider the following:
Depending on whether you have your old Install Discs or you did a download, and don't have a previous Install Disc, makes a difference as to how you qualify and will install the new Upgrade.
The Upgrade requires Ulead software installed on the Hard Drive, or a Previous (sometimes Full, sometimes an Upgrade, sometimes both qualify) Install disc for Media Check software validation. So if you don’t have a previous Install Disc, don’t uninstall your old programs, you may damage you installation and then you will be out all together. Just try to install the Upgrade and hope for the best. You can always delete the Shortcuts after the new install, to the other software Version names without damaging anything.
If you do have a previous Install Disc, make sure it qualifies, then yes uninstall all of the previous versions, beginning with the most recent going back to the oldest last.
Once the older programs are uninstalled visit the Old Version Folders, recover and move your personal Galleries, Libraries, etc. before you delete the Folders in preperation for the Upgrade.
