can't create video file 1440 x 1080
maxfrost01
motherboard: Intel Corporation DX58SO AAE29331-501
processor: Intel i7 920 2.67GHz
ram: 6 GB
Video Card: NVIDIA GeForce 7600 GS
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 2.2 TB
Post by maxfrost01 »
This is my first high-def project with X3. All my clips are 1440 x 1080 but, for some reason, the Project Properties are 720 x 576.
Don't see that as any problem providing I can select the higher quality settings when I go to create a Video File. And that's where the problem begins.
If I go Share/Create Video File/Custom I can see the properties in the Save Options box are 720 x 576 and I can't change them.
I've tried clicking on Options and looking under the Compression tab but my only options there are PAL DVD or NTSC DVD. I can't find any option that will let me get the file back to the original properties of 1440 x 1080.
I'm NOT trying to create a DVD - just a high quality file that I can play back on my computer and on my HD TV.
I'm sure I didn't get this problem with X2..........
Any ideas?
Max
Re: can't create video file 1440 x 1080
Post by Trevor Andrew »
Hi Max
You are correct, there are more user options with earlier versions, X3 has lost a lot of, shall we say the manual approach.
The project properties are not a problem, just make sure you have the Aspect Ratio set to 16:9, then the video will display correctly within the preview screen.
Can you give some details of your original video files, what type are they?
If you just need PC playback then you could try one of the HD options —HDV for PC.
Otherwise you would have to create your own template using Custom, although the Make Movie Templates Manager maybe a better option. Some formats allow you to User define the frame size.
maxfrost01
ram: 6 GB
Hi, Trevor
Not quite sure I follow your comment about the display in the preview screen. What has that got to do with the Video File I want to create?
Certainly the image in the preview screen looks good/HD quality.
HDV for PC looks like a good way to go and it does give me the 1440 x 1080 that I want, but I notice that when I use one of the presets (such as HDV for PC) I lose some of the options - particualry compression which I always used to set at the max 100 (don't know what it actually did but going to the max always seems like a good idea :lol: )
Happy to create my "own template using Custom" as my settings are the same from one project to the next but how? If I can't find the options I want (especially 1440 x 1080) then how can I create the template? :?
Clip properties are MPEG-2 Video - Upper Field First; Attributes 24 bits, 1440 x 1080, 16:9; Frame Rate is 25,000; Data rate is 25,000 kbps.
Max
I really don't see what your problem is... Selecting Share > Create Video File > HDV for HDV (or even for PC) will give you rock solid HDV with absolutely identical properties to your original video. You can't get any better because those properties are the international standard for HDV (which I am assuming you are using). I use it all the time with excellent rests using HDV from my Canon HV20.
In fact it was not compression that was regulated, but a supposed balance between the final quality and the time taken to produce the rendered video. Setting it to 100 meant a longer render but a theoretically, but only slightly, higher quality. Some people swear by it, but apart from playing around with it once or twice to gauge the end result, I have ignored it for the all the years I have been doing video editing. Instead, I always accepted the default as a good balance between rendering time and end quality. I was never disappointed. And with HD video, especially using the international standard properties, there is no point worrying about it since as I said at the outset, you will be getting identical properties to your original video, and -- as far as my eyes can detect -- absolutely identical properties. Moreover, like you I play back my new HDV either on my computer with full HD monitor or via my network to my big screen HDTV. The results, as I say, are excellent! :lol:
maxfrost01
ram: 6 GB
Thanks, Ken
I am reassured.
I'd still be interested to know how to create my own template! Just curious................
Max
Select Settings > Make Movie Template Manager. Then in the dialogue box which appears, select MPEG Trasnport Stream (.m2t) as the format and give the template a name. You will find that the default properties are already set to 1440 x 1080 though you could also select 1920 x 1080. Compression on the third tab would need to be changed upwards. However, you will note that the only available option is VBR -- as opposed to standard HDV's CBR 25 Mbps. So to get a roughly equivalent average VBR would probably need to increase this to 35 Mbps. Note also that the only audio choices available are LPCM and Dolby, as opposed to standard HDV's mpeg layer 2 audio.
If you want an absolutely exact copy template of your original files, then in Make Movie Template Manager, you would select Add, nevigate to one of your original files, and link to that. But as I say, there is no point in doing this as the properties of the existing HDV for HDV template are already standard HDV properties identical to your own.
maxfrost01
ram: 6 GB
Thanks, Ken - seems to work nicely.
Although, in summary, I think you're saying "quit messing around and use the existing templates".
Last question (probably) can you explain the difference between "HDV for HDV" and HDV for PC"?
To begin with - what does HDV stand for?
Max
I guess that is my message ... if in fact you are using HDV and its from a HDV camera! :lol:
As far as the difference between "HDV for HDV" and HDV for PC", frankly I have no idea why they have this in the program. As far as I am aware, HDV is HDV is HDV... and if you look at the properties for both these options, as far as I can see, they are identical! :roll:
As for HDV, it was the original High Definition Digital Video for the consumer market. The HDV cameras use -- as you are probably aware -- mini DV tapes, and the format is high def mpeg-2 UFF (well, you know the properties by now!!) -- although you can also set the camera to record in standard definition DV/AVI which curiously enough uses Lower Field First... The other, more recent high def format is of course AVCHD which is mpeg-4, and more highly compressed than HDV (and requires much greater computer resources to edit and play...)
maxfrost01
ram: 6 GB
Ah, so, HDV should really be HDDV :)
Interesting to note that the AVCHD takes more computing power than MPEG2.
I've been using my HD/mpeg2 camera for about six years now and was thinking about an upgrade - all the new models seem to be AVCHD.
Thanks as ever for the advice and help.
Max
