Perhaps there are X3 users who can assist me before I waste a few hours experimenting.
Situation: You have two hard drives - you intend to have programs reside on one and data on the other. All things being equal - one drive spins faster than the other. i.e. 7200 Rpm vs 5200 rpm vs 10,000 rpm
Question: Would you place the X3 program on the faster drive and the data on the slower drive OR visa versa. I am thinking (dangerous) the data (smart proxy files, saved projects and video files) should be on the faster drive since the "program" probably doesn't use the program drive much and uses more CPU / memory. Now I am just guessing here, but hope someone has done this already.
Thanks for your assistance.
[size=150][b]Summation: I have two hard drives - one is faster than the other - which drive should I put the X3 program on and which should I put the data on?[/b][/size]
Cheers
JackTheBear
2 Hard drives - different speeds -
JackTheBear
- motherboard: Asus Rampage
- ram: 8gb
- Hard_Drive_Capacity: 500g
- Monitor/Display Make & Model: AOS LED
Canon HF10 Video Camera - Asus Rampage MB - Intel Quad 4 Core 9550, 8 gigs DDR2, Pioneer BD203, TSS DVD, Windows 7 Ultimate 64bit.
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Re: 2 Hard drives - different speeds -
Suggestion: google performance balancing with multiple hard drives. My guess is that the most important thing to have on the fast drives is Windows paging file, and the data; however I have not done this and thus the suggestion to google for the answers... Al
User for more than 10 years.
I'd put the video files on the faster drive. And if you really want to speed things up, try putting your original files on one drive and render the edited output to the other. That way the read/write head doesn't have to jump back-and-forth as the drive switches between reading & writing.
In cases where drive speed is the bottleneck, that will help. Of course, if there's lots of processing & transcoding and the CPU is the bottleneck, it won't make any difference. (It takes about twice as long to copy to a different folder on the same dirve as it takes to copy to a different drive.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
I've had a multitude of different drives on my editing pc.
10,000rpm x 3 for triple booting
7200rpm for data x 2, in raid 0, in raid 1 and now sata drives which I have as raid 0.
I haven't noticed any real difference in timings and I work most days on editing and dvd production.
If they are identical in capacity then I'd choose the faster drive for the data.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Hello JackTheBear,
I'd use the slow disk for the system files, where you install Windows, programs and stuff. Since the system will just load everything to the system's memory when running the OS and program, then use the faster drive for data, specially if you will be working with videos and large files that needs to be read quickly, This will allow the program to read/process/write more efficiently.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
JackTheBear
- ram: 8gb
Thank you all - I will use the faster drive 10,000 speed for data and the 7200 for the program and will report if I noticed a difference
Thanks again for your input. I was thinking the same way.......but sometimes computers make no sense and X3 sometimes makes even less sense - ha
Jack T Bear
Jack T Bear
