I want to create a outline round rctangle on a image like in the files attachd. Can you help me? Thanks.
Alessandro
Outline round rectangle board on an image
- Attachments
- 61.png (43.09 KiB) Viewed 18480 times
- 60.png (42.7 KiB) Viewed 18480 times
Re: Outline round rectangle board on an image
Something like this:
Thank you Ron, the last question.
How can I control the angles to have small rounds like in the image.
Ciao,
Alessandro
Ciao,
Alessandro
- Attachments
- 111.jpg (91.04 KiB) Viewed 18471 times
Use the Path Edit Tool, and on the Attribute Toolbar click the Edith Path Object. Your Path Object will then look like thin lines with nodes. Just move the nodes adjacent to the corners to make the round corners smaller.
Create and control the outline is ok, to put the image inside in difficult. Have a suggest? Thanks for the patience, bye.
Alessandro
Alessandro
- Attachments
- image.jpg (218.7 KiB) Viewed 11973 times
Ok, try it this way...
Wouldn't it be much easier to change the size of the rounded corners at the beginning, just after drawing the rectangle, by using the 'Rounded Rectangle' settings in the Tool Settings window in the right hand pane?
You can adjust this setting after filling the rectangle with the image too.
Thaaaanks, now I have the right thing. A special thank to Ron (very patience and helpful) and also to sisom for the last suggestion. Hope to not disturb you for a lot of time. Ciao from Italy.
Alessandro
Alessandro
Thanks sisom
