16:9 format help
Malc
operating_system: Vista Business
motherboard: Gigabyte
processor: Core2 Duo Pentium 2Ghz
ram: 4GB
Video Card: Asus 210 - 1GB RAM
sound_card: Realtek
Hard_Drive_Capacity: 1TB
Re: 16:9 format help
Post by Malc »
Hi Trevor,
I can confirm that works... I used the DVD factory to produce a DVD which plays just fine. The part that I'm having problems with is viewing the converted AVI on my internet ready TV. Having produced the 16:9 avi as per steps 1 - 5 below, I then take that file and select the "Create video file" under the share folder to select a format (such as MPG or MP4) that the media player can stream. No matter what option I chose it simply won't fill the screen - often it actually seems to compress the clip into the 4:3 format so everyone is tall and thin.
Post by Trevor Andrew »
Hi Malc
Quick reply…Not much time at the moment.
Can you look at your Project Properties and make sure that Non Square Pixel Rendering is selected.
When you Share Create Video File, from the save window select “options”, again make sure you are using Non Square Pixel Rendering
Malc
ram: 4GB
sound_card: Realtek
Post by Malc »
Trevor,
I used the 16:9 clip made as per instructions, saved the file as mpg and confirmed that there was a tick in the option to use non-square pixels option. I then played the resulting clip on the PC using media player - it plays OK and the aspect is 16:9. launched the nero media server application, selected the media option on the TV, navigated to the file and selected it to play - came up on the screen in compressed 4:3 aspect with black bars.... :? :evil:
I've attached the properties of the end result
Malc
Have you tried adjusting the aspect ratio on your TV's remote control?
Malc
ram: 4GB
sound_card: Realtek
Post by Malc »
Hi Ken,
It's set to 16:9 - and I can play downloaded trailers for movies etc from the same location on the TV just fine. This only seems applicable to video produced from clips taken from the camera and then processed to 16:9.
I don’t understand whats going on here.
The disc you created is a standard 16:9 DVD and plays on your remote players as ok.
However the raw Mpeg played via the nero media server application shows as 4:3.
It has to be the settings of the media server, I do not have any experience with this application.
What type of files play ok, what are the type you download.?
I still think it’s a Non Square Pixel issue.
If your media server does not support Non Square Pixels then it will display the 16:9 as 4:3.
Earlier I think you mentioned Mp4 files………
Convert your “DV Avi 16:9” to MOV MPEG4 using 1280 x 720 frame size.
You will have to use the Custom option and User Define the frame size.
Malc
ram: 4GB
sound_card: Realtek
Post by Malc »
Trevor, that makes two of us !
Ok I took the re-rendered video that was the result of the above procedure and this time stuck it on a memory stick, so it was using that rather than the media centre to play over the network. Same result !
I've gone through all the options for the picture in this function and in terms of size there is "full" or "original". "Original" displays the clip in the centre of the screen, approx a foot square (TV is a 37" LG). "Full" displays the clip full height of the TV but compressed with black borders left and right. The strange thing is that I have a HD trailer for a computer game and for Avitar, which play fine at full screen. OK I know these are 1920 x 1080, so maybe the issue is with the TV, I don't know.
Any other suggestions ??
Malc
ram: 4GB
sound_card: Realtek
Post by Malc »
trevor andrew wrote: Earlier I think you mentioned Mp4 files………
I'll give that a go in a moment
Update:
Nope...
Did manage to get it near by setting to 1920 x 1080, but it was still slightly cropped on one side (possibly as I re-positioned the clip to suit the frame after applying the distort/full frame/aspect ratio option), but the audio was not supported, and the image wasn't great
I'll keep trying
TheBackslider
motherboard: P5KPL-AM SE
processor: Pentium R Dual-Core
Video Card: ATI RADEON 3600 Series
sound_card: REALTEK HIGH DEFINITON AUDIO
Hard_Drive_Capacity: 220
Post by TheBackslider »
Hello there! I am new member of Corel Forums. I just wanna congratualte myself for that.
Anyway, I am now using Corel VideoStudio Pro X3. I can't make my videos into widescreen. Can you please tell me step by step how to make videos with 16:9 aspect ratio using Pro x3? Please!
I need a simple step by step instruction.
TheBackslider
Just why still there are videos not in widescreen format even if I have checked the Perform non-square pixel rendering?
Welcome to the forum
You haven’t given much information regarding your video file or any process you have tried.
Please read this before posting
It gives some details of what is required to help your problem.
Just to get you started, please right click on of your video files and select properties, What are they?
Please leave Non Square Pixel Rendering checkes/selected
Malc
ram: 4GB
sound_card: Realtek
Post by Malc »
TheBackslider wrote:Hello there! I am new member of Corel Forums. I just wanna congratualte myself for that.
Trevor has already outlined the step by step procedure in this thread. For me it works fine when producing a DVD. My problem is that my internet ready TV won't display a wide screen full screen picture when streamed over my network from the PC.
nara76
operating_system: Vista Home Basic
processor: amd athlon
ram: 3gb
Hard_Drive_Capacity: 5gb
Post by nara76 »
hi there , i have read all the posts and tried mathching the properties but still my movies are displayed in 4:3 mode can anyone help me change this to 16:9...previously all of my movies were 16:9... i dont knoe how it changed...any help
Nara76, welcome to the forums, :)
We need to know more information, like what version of VS you're using, and something about the video files. You can go to the sticky topic at the top of this forum entitled, Read this first before posting, for a guideline on what and how to obtain that information.
