I have Windows XP Professional.
Intel Celeron 2.8Ghz CPU.
768MB DDR Ram...I know I should have 1GB but Christmas IS coming.
600GB of Hard Drive space
When I went to burn several video files, creating a menu, the first video was fine, the others had problems.
On MY DVD player a MAGNAVOX MWD 7006 Model, not your top-of-the-line, when you would click on the other videos to
play, the player would sit there, then come back to the root menu, as if it had a problem reading the file.
On another DVD player, the sound was not in sync with the video, when you would press stop then play, this would correct the problem. On another DVD player, you could not select, the first video would be highlighted and you could not select others.
Clicked YES to perform SmartRender.
Project Settings
16:9
MPEG Files
24Bits 720x480 29.97fps
Lower Field First
NTSC
Variable data rate: (Max. 8000kbps)
Audio data rate: 384 kbps
Dolby Digital Audio: 48KHz
ONLY BOX CHECKED: Do not convert compliant MPEG files
Settings and options
Preferences
Advanced Tab
3 boxes checked ONLY
VCD player compliant
Anti-flicker filter
Max. 30MB Menus
Moving Path, Show Highlight Button, Create To Disc Checked.
Archive images of slideshows UNCHECKED.
I will try to install UPDATE PATCH #1. It says that it corrects DVD Menu Problems and so on.
COULD THIS fix my problems???
Thanks!
zippy
