PSPPX2 pasted objects are resizing themselves
chrustasia
motherboard: ASUSTek Computer INC. Kelut 2.02
processor: 2.20 gigahertz AMD Athlon XP
ram: 1024 MB
Hard_Drive_Capacity: 167 GB
Post by chrustasia »
When I copy and and paste an object or photo it always pastes a smaller dimension than the original. I'm copy/pasting between Photo X2 windows.
For example, I am making a photo array. My original photo or object measures 6" x 9". I copy and paste it onto another canvas (sized 18" x 24") but the object measures only 3 x 5 rather than 6 x 9 on the new canvas. I can resize it larger but it loses quality, of course.
Why does this happen and how do I keep things the same size from window to window? I save photos as PNG when I'm going to work on them, if that makes any difference.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: PSPPX2 pasted objects are resizing themselves
Post by LeviFiction »
Do they have the same ppi? Go to your Image Information dialog from the image menu. Image->Image Information(Shift + I)
You should see an area that says Pixels per inch or pixels per centimeter. Do these numbers match between images? If not then something that's 6x9 in one image with a lower ppi will appear smaller in an image with a larger ppi.
Remember, how large the image is in inches is determined by how many pixels are in an inch inside that image and how many pixels you have.
Does the actual pixel count change? That is the most telling.
Instead of copy and paste (if you are using Windows instead of tabs) you can drag layers between images and see if that makes a difference. Just go to your layers palette, grab the layer you want to copy into the other image and drag it ontop of the other image and release it should add it as a new layer.
jaxman43
motherboard: PEGATRON CORPORATION 2AC2 2.00
processor: 3.40 gigahertz Intel Core i7-2600
ram: 8 GB
Video Card: NVIDIA GeForce GT 520
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: HP 2311
Post by jaxman43 »
Thanks for that tip LeviFiction. I didn't know you could drag and drop that way.
Larry
