Animation Shop - How to transition from last frame to first
GIF Animator, SmartSaver Pro, Plugins, Applets....
jer826
System_Drive: B
Post by jer826 »
I'm using Animation Shop to create an animated gif. I have set the ag to repeat indefinitely. I have added transitions for each frame. However, I have not found a way to transition from the last frame to first frame.
Re: Animation Shop - How to transition from last frame to fi
Post by BrianCee »
Well - I don't know if it's the official way - perhaps someone more proficient than me at using the GIF animator will correct me - but when I wanted a similar effect I duplicated the first frame exactly to the last frame and cut the time (delay) on first and last to half - then you can have transitions between frames but last switches seamlessly to first - worked fine for me.
