VideoStudio Crash when I try to edit
Re: VideoStudio Crash when I try to edit
Post by Black Lab »
It's my understanding that it is not just QT 7.6.6, but any newer version. General advice is to roll back to an older version of QT.
AlongTheWay
motherboard: Intel
processor: Intel i7
Hard_Drive_Capacity: 1 TB
Post by AlongTheWay »
This is very interesting. I loaded a .mov file from my iphone and found a similar edit crash problem on Video Studio 11plus. So I thought I needed an upgrade and went to Pro X3 but found it did the same thing. I loaded a .mov file from my Canon 5D and it works properly. I wonder what the difference is between .mov files? I hope you find a fix or converter for this little issue. I'll be watching.
Corel Video Studio X9, VideoStudio11+, ProX3, PhotoImpact 4, PhotoImpact 12, PhotoImpact X3, Audacity, Virtual Dub, Canon Digital Photo, Anim8or, Blender, Gimp, Sony DCR-TRV260, Hitachi VM-SP1A, Canon D30, Canon D5 Mark II, Canon D7, Contour +2
pvreditor
processor: Intel i7
ram: 24GB
Hard_Drive_Capacity: 2TB
Post by pvreditor »
I have also had crashes when I try to work with video from cell phones. (Some new cell phones actually shoot 720p HD, and I have a need to work with such clips.) I looked online for free software to convert video files and found something called MPEGStream (or something close to that). Now, I use the conversion software to convert the files to AVI format and I can edit those with no problem. It's a bit of a hassle to have to spend time converting the files, but a 30-second file is converted in a couple of minutes.
Bob Kovacs
http://www.bobkovacs.com
Post by Black Lab »
SUPER is another free converter that seems to work well.
hmauh
motherboard: Intel G41
processor: Pentium Dual Core 2.7GHz
ram: 2GB DDR-II
Video Card: Intel G41 Express Chipset
sound_card: RealTek High Defination
Hard_Drive_Capacity: 500GB
VideoStudio Crash when I try 2 use HD instant projects
Post by hmauh »
Hi All, i m also facing same problem when i try to use HD instant project. this probelm is occuring only in HD projects. i have tried each nad every thing but i m unable to solve, here are screen shots of crashes.
http://picasaweb.google.com/raavian/CVS ... 8597308050
http://picasaweb.google.com/raavian/CVS ... 3063420418
kindly provide solution if anyone has.
Crash screen shot
Crash screen shot
CVS crash I.jpg (100.54 KiB) Viewed 933 times
Crash Screen shot II
CVS crash II.jpg (79.72 KiB) Viewed 933 times
Post by Black Lab »
hmauh, without knowing your clip's or project's properties we would only be guessing. Please read the following and supply the requested info.
http://forum.corel.com/EN/viewtopic.php?f=1&t=8959
SWATLEADER
motherboard: ASUSTeK COMPUTER INC. P8H61-MX R2.0 Rev X.0x
processor: 3.40 gigahertz Intel Core i7-3770
Video Card: Intel HD Graphics 4000
Hard_Drive_Capacity: 1254.02GB
Post by SWATLEADER »
1. SUBJECT: Ulead VideoStudio Pro X3 Crashes when trying to play clips at 1.00x speed during multi trim or when previewing clips in multi trim
2. Describe your problem: Program encounters an error when trying to play clips in the multi trim menu and displays the following error -
3. What devices are involved and their mode of connection?: Hauppauge HD-PVR which is connected to the tv with component cables and to the computer with USB
4. The Version of program is being used? VSX3
5. Please list all patches/updates that have been installed relating to that version of the program. All patches/updates are up to date
6. Details of the source files.
a. Where did they originate - Hauppauge HD-PVR
b. How did they get onto your hard drive - USB
c. Type of video - Video type is H.264 Video, File Format is NTSC HDMV
d. Video data rate - Variable bit rate (Max. 19999kbps)
e. Type of audio - Dolby Digital Audio
f. Audio data rate - 384 kbps
7. Project Settings - PAL (25fps), MPEG files, 24 bits, 720x576, 25 fps, Lower Field First, (DVD-PAL). 16:9, Video data rate: Variable(Max 8000kbps), LPCM Audio, 48000Hz. Stereo
8. PAL or NTSC - PAL
9. Did this error occur at the SHARE - No this error occured while editing in the multi trim section
10. Error Codes (if any): C:\Users\User\AppData\Local\Temp\vstudio_1.6.0.272_20101121_222256.DMP
Operating System: Windows 7 Home Premium
32 bit or 64 bit: 64 bit
Motherboard: Acer Aspire M3400
Processor: 2.70 gigahertz AMD Athlon II X3 425
Ram: 3GB
Video Card:ATI Radeon HD 4250 Graphics
Sound Card:ATI High Definition Audio Device
Hard Drive Capacity: 1254.02GB
Memory: 2800 Mb
I hope someone can help me with this problem as there was no problem with editig a week ago but since i recently recorded more footage and went back to edit them it crashes everytime. I'm sorry if some of the information is wrong, i'm about of a noob when it comes to the technical side of computers so let me know if i need to change anything to help me get the right solution
pvreditor
processor: Intel i7
ram: 24GB
Post by pvreditor »
I don't know exactly what format video you are trying to edit when VS crashes on you. If it is something other than the usual format that you work with, I strongly recommend that you get some video conversion software and convert the problem video to something more universal, such as AVI. I use a program called MPEG Streamclip, which I downloaded for free. It's not perfect but it can generally convert oddball video formats to AVI, and I can then usually edit the AVI file with no further problems.
Hope that helps!
Bob Kovacs
hmauh
ram: 2GB DDR-II
Re: VideoStudio Crash when I try HD Project
Post by hmauh »
i just installed CVS Pro X3, downloaded instant projects, and tried to used. there is no issue with any instant project category but HD PROJECTS. i have attached all screen shots, and project properties. my system properties are given in my profile.
2 - Project properties.jpg (92.43 KiB) Viewed 2643 times
3 - Probelm with HD Project.jpg (146.01 KiB) Viewed 2478 times
4 - HD Project Problem.jpg (145.07 KiB) Viewed 2478 times
hmauh
ram: 2GB DDR-II
Post by hmauh »
here is the dump file that was generated.
vstudio_1.6.2.21_20101123_180135.rar
(32.89 KiB) Downloaded 119 times
