The program has encountered an unspecified error and has stopped functioning. Please contact Corel Technical Support and send the dump file for analysis.
C:\Users\NAME\AppData\Local\Temp\vstudio_1.6.2.21_20101106_181020.DMP
How do I send this?
You send via email to them. http://www.corel.com/servlet/Satellite/ ... 4151700373 scroll down to where it says Unable to chat, there's a link for emailing.Giancarlo84 wrote:I'm getting the following message:
How do I send this?
It would be helpful if you would post the properties of your clips, including the audio. WAV audio is usually solid as a rock and doesn't cause problems.b1a1 wrote:I am geting the same message. does your video have an audio track. I suspected the problem might be the wav audio file embedded in my clips. when i mute the clips i can edit without issue. when I play or split the audio track, i get the error message and the program shuts down. I am using a canon 5d mk2 and a 7d.
camera is Canon Vixia HF S200, AVCHD formatRon P. wrote:As Jeff asked earlier could you please provide the information on what type of video files you're trying to edit when you get these crashes? Right-click on one of them in the Library or Timeline, select properties and post them here.
Also what specifically are you doing when the program crashes? Editing covers a lot of actions, like adding filters, (if so what filter(s)), cutting/trimming, adding transitions? Is this crash occurring while doing the same thing?
http://en.wikipedia.org/wiki/Hyper-threadingwikipedia wrote: Hyper-threading (officially Hyper-Threading Technology, and abbreviated HT Technology, HTT or HT) is Intel's term for its simultaneous multithreading implementation in its Atom, Core i3, Core i5, Core i7, Itanium, Pentium 4 and Xeon CPUs.
