Can you paste into all frames of Ulead GIF Animator?
GIF Animator, SmartSaver Pro, Plugins, Applets....
c627627
Post by c627627 »
Instead of pasting an image into every single frame, can you paste to all frames in Ulead GIF Animator?
Can you paste the same image to a specific location (for example the lower left corner) of every frame?
VikingAnimations
processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
ram: 4 GB
Hard_Drive_Capacity: 1 TB
Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Re: Can you paste into all frames of Ulead GIF Animator?
Post by VikingAnimations »
Remember this important fact: When you paste into GA 5, you are not pasting into a frame - you are adding an object to the Object Manager. It will be visible in the frame that was selected when you hit "Paste," but now that you have the object added, there's no point adding it again.
See Synchronize Objects Across Frames on how to easily get that one object added to all the rest of the frames.
c627627
Post by c627627 »
Edit > Paste Image > Move image where you want it to be
Frame > Synchronize Objects Across Frames > CHECK: Active object(s) only and Visibility and Apply to All frames > OK
I couldn't find this anywhere on the internet using search terms "paste image in all frames" which is how new users search for this.
Thank you!
VikingAnimations
ram: 4 GB
You're welcome. :wink:
As I've run across this question before, I added it to the FAQ page of my site. How do I "paste into all frames?"
c627627
Post by c627627 »
That's great, I hope it helps people but (if I may) see where you put "checking the applicable boxes." It will take new users 45 minutes to figure out what that means. :)
It would take them 5 seconds if you put this: Edit > Paste Image > Move image where you want it to be
SELECT: Active object(s) only
CHECK: Visibility
SELECT: Apply to All frames > OK
VikingAnimations
ram: 4 GB
It's right there for all to see, at the link noted. It shouldn't take anyone 45 minutes...
StarDebut
Post by StarDebut »
I would like to use this process to add a foreground image to my current animation project, but the transparant parts are being filled in with white space.
I have followed the technique above
and have check the box "apply the following attributes:"
Transparancy
VikingAnimations
ram: 4 GB
Does this foreground image you're adding actually have a transparent background itself? If not, then you'll have to use the Magic Wand tool to remove the background white space. Without any further information, that's my best guess as to your issue. The crystal ball is in the shop for repairs. ;)
