Hi All,
I captured approximately 1 hour DV file contained different scenes from different places. Now, I would like split this file for smaller parts and save them as a separate .avi files.
Is this possible to do this by VSX3 (e.g. cut or multitrim on timeline and save to separate folder each pieces?
If X3 cannot do this, what software you can recommend for relatively easy and quick multi-split, without loose quality?
Thanks for advise.
Wesley47
Split large video file
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: Split large video file
Hello Wesley47,
I'm Abiel from Corel Support. With regards to your concern, yes it is possible for you to split a large file and save it to individual .avi files.
Here's the steps on how to split a video or clip.
To split a clip into two
1. In Storyboard View or Timeline View, select the clip you want to split.
2. Drag the Scrubber to the point where you want to split the clip.
Click
or
to set the cutting point more precisely.
3. Click
to split the clip into two clips. To remove one of these clips, select the unwanted clip and press [Delete].
For more ways on how to work with Clips, you can click here.
Click
or
to set the cutting point more precisely.3. Click
to split the clip into two clips. To remove one of these clips, select the unwanted clip and press [Delete].For more ways on how to work with Clips, you can click here.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
But if I am reading the OPs question correctly, he wants to batch cut & save as a separate file. I am not a user of multi-trim so I do not feel qualified to answer.
Jeff
Dentler's Dog Training, LLC
Wesley47
- motherboard: ASUS P5Q PRO TURBO
- processor: i5-2400-3.10GHz
- ram: 8 GB
- Video Card: ATI Radeon 4800
- Hard_Drive_Capacity: 1.3TB
Thanks Abiel,
"save trimmed file" works fine, but to save, e.g. 25 cuts each, takes time, especially when I have 20 large files for split. I would rather prefer, like Blak Lab says, batch cut and save as separate file software. Maybe in future version od VS?
Any other tips guys?
Best regards
Wesley47
Best regards
Wesley47
teknisyan
- ram: 4 GB
I'm not sure if VS X3 has a batch process feature but it does have a batch convert which I'm sure is not the one that you are looking for. But if you have installed the DVD Movie Factory 7 Se, then you may want to take a look at the multi-trim feature and the EXPORT SELECTED CLIPS.
Like reading blogs?
About Tech
About Sports
About Tech
About Sports
- ram: 2 GB
- sound_card: Intel GMA 950
There are two methods available to have your clips as separate items.
Either you can
1. Split by Scene whilst capturing (transferring) the video from your camcorder to the computer. This produces a separate standalone small video for each scene.
2. Capture as one large complete video file THEN apply split by scene. This produces several thumbnails in your project library. You treat these thumbnails in the same way you would had you opted to do the other method "Split by scene whilst capturing."
Further details and explanation can be found by clicking the following link:
From Camcorder to DVD with Video Studio
Scroll down to the sub heading "Split By Scene"
Either you can
