Crash during rendering using VSX3
Re: Crash during rendering using VSX3
Post by Black Lab »
Does anyone know what I a doing wrong or have any suggestion.
Yes, since you have had success with X2 use it!
Post by Trevor Andrew »
MSP-Diver wrote:Ok somehow, I was able to burn a DVD through 7SE. I have made all the menus for Blu Ray and want to burn in 7SE. But here is the problem. When I want to burn using the blu ray burner 7SE will not let me highlight Create Disc image. Also and probably most important and why I have burned 2 blu ray coasters is under the more blu ray options (the little disc in the bottom left hand corner of stage 3) will not let me highlight Buffer Underrun protection. This is the exact wording of the error I have gotten twice before while attempting blu ray burn. Does anyone know what I a doing wrong or have any suggestion. I am so close to completing this project.. Also it will not let me select a write speed of the blu ray burner. It is always set to maximum. Anyone?
Did you try creating a Bluray Folder as mentioned earlier,if this process is sucessful then we can assume there is no problem with rendering.
MSP-Diver
motherboard: Asus P6X58D
processor: I7 930
ram: 6gb
Video Card: NVIDIA FX-1800 250mb
sound_card: OnBoard
Hard_Drive_Capacity: 2TB
Post by MSP-Diver »
Created the Blu Ray folder. It said it was succesful. The folder had several different files. When I clicked on the main movie only about half was there. I really think the problem might be the Buffer Underrun button that is grayed out in the Blu Ray authoring. I authored a DVD in the same drive today no issues. The disc burned in about 8 min. When I entered the DVD in the same drive I could check the buffer underrun button. My research on this keeps the dis from getting to far in front of the buffer that is provided to the drive from 7SE. I know for a fact that my Quad core I7 can handle this. I have plenty of hard drive space. Both drives spin faster then 7500rpm and I have 6 gb of memory. I checked on my lite on blu ray burner and it specifies that it has buffer underrun protection. I believe this to be true because of the DVD authoring. I have seen this problem on other reviews. Does anyone no a go around or a patch fix. Also why doesn't 7SE allow me to change the write speed from MAX to something lower.
The Buffer Under-run is related to the actual burner.
When you created the Blu Ray folder you didn’t use the burner, just the software to create the folder.
If the folder content is not complete then the problem is with the project and the way its converted/rendered….. not the burner.
You should investigate why the files are not complete.
The actual files --- MTS files are saved to the Stream folder within BDMV
Are you sure some of the movie content is missing.?
Are you able to play the folders content on your pc?
As far as I know once you have created the folder you should be able to burn it to a disc as a data file and it will play in a DVD player.
MSP-Diver
processor: I7 930
ram: 6gb
sound_card: OnBoard
Post by MSP-Diver »
I can find the blu ray file in my pc. It is broken down into the trailer part and the movie part. Then it gives me several different folders of the menus. I can play the movie it lasts for about 25 min then ends leaving abour 37 minutes left. I can watch my rendered file find on PC and have even watched through a portable hard drive on my home theater. The problem has to be with Movie Factory 7SE. Like I said the DVD burn came out fine. I don;t think the software is giving information fast enough to the burner. Corel support is bad. Expected wait time 1 min. On hold for over hour. Really think twice before I buy another Corel product.
jmccaski
motherboard: DELL Inc. 0X501H A02
processor: 2.67 gigahertz Intel Core i7 920 Quad Core
ram: 12 GB
Video Card: NVIDIA GeForce GTX 260
Hard_Drive_Capacity: 2 X 1.5 TB
Post by jmccaski »
OK, here is the log data typical of my (very many) VSProX3 crashes. Any help would be appreciated:
- System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2010-11-07T07:53:43.000000000Z
EventRecordID 13594
Channel Application
Computer John-PC
Security
- EventData
vstudio.exe
13.0.0.0
4bd90870
H264VDec.dll
4.2.0.12
4bd90aec
c0000005
00011426
1638
01cb7e50745c9989
C:\Program Files (x86)\Corel\Corel VideoStudio Pro X3\vstudio.exe
C:\Program Files (x86)\Common Files\Ulead Systems\MPEG\H264VDec.dll
23be139b-ea44-11df-905e-a4badb01fcd5
PaintShop Photo Pro X3
Visual Studio Pro X3 13.6.2.21(with SP 1, SS Update, Fix for MLE Database patches installed)
No one here -- (well, one, recently, a guy called Abiel) -- works for Corel. So posting bits of dump files means absolutely nothing to anyone (although I wonder about Abiel...)!! :lol:
cdoughertycd
motherboard: ASUS PHTD DELUXE
processor: 4 Core 2-93 gigahertz Intel Xeon
ram: 36 GB
Video Card: AMD Radeon HD 7700 Series
sound_card: AMD HD Audio
Monitor/Display Make & Model: Samsung S24B300
Corel programs: many back to VS 5, all up to 2022 Ult
Post by cdoughertycd »
You might have fixed your crashing problem by now but I was having the same problem with huge video files captured from my Canon CMOS HD camera, and tonight figured out if I "stop capture" into shorter length clips I am not having crashing with VSX3 or problem of in the middle of a long clip the video goes black but the audio stays on. I almost gave up but now I'm able to finish a project that is about an hour long using 4-6 minute clips instead of one long one.
jmccaski
ram: 12 GB
Post by jmccaski »
I just was following the instructions posted by Rob717 on Mon Nov 01, 2010 8:57 am earlier in this thread.
jmccaski
ram: 12 GB
Post by jmccaski »
cdoughertycd wrote:You might have fixed your crashing problem by now but I was having the same problem with huge video files captured from my Canon CMOS HD camera, and tonight figured out if I "stop capture" into shorter length clips I am not having crashing with VSX3 or problem of in the middle of a long clip the video goes black but the audio stays on. I almost gave up but now I'm able to finish a project that is about an hour long using 4-6 minute clips instead of one long one.
Unfortunately, my finished clip is only 1 min 36 sec long. It was made from about a dozen longer clips, but I trimmed them, added transitions and a couple of effects as a demo for a very short (2 evenings, over now) video class I was taking.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Hello MSP-Diver,
Have you tried updating your VideoStudio? If not then you can download all the updates from this link.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
MSP-Diver wrote:I can find the blu ray file in my pc. It is broken down into the trailer part and the movie part. Then it gives me several different folders of the menus. I can play the movie it lasts for about 25 min then ends leaving abour 37 minutes left. I can watch my rendered file find on PC and have even watched through a portable hard drive on my home theater. The problem has to be with Movie Factory 7SE. Like I said the DVD burn came out fine. I don;t think the software is giving information fast enough to the burner. Corel support is bad. Expected wait time 1 min. On hold for over hour. Really think twice before I buy another Corel product.
Hi MSP-Driver
Sorry for the delay in replying, your BluRay folder should be called BDMV.
You should be able to play this folder and the entire content as a DVD using your PC....That is the whole DVD will play menu’s and all.
If you do not have a media player that well do this, I used the VLC media player.
Start the media player then Media - Open Folder—browse for the BDMV folder.
If the folder plays as ok then the rendering process is working ok.
As mentioned earlier the BDMV folder can now be burned to disc as a data file/folder and should play ok. If this fails then the problem lies with your burner process/disc compatibility not Movie Factory.
