Audio filter cannot be used
link_xue
motherboard: Intel
processor: Intel
ram: 1GB
Video Card: integrated
sound_card: integrated
Hard_Drive_Capacity: 120G
Post by link_xue »
Hi all, one issue needs your kind help. I used once and it worked. Could the latest update affect this? Thanks in advance. Link :D
Describe your problem: when I split the sound off the video I can not apply the audio filter to the sound clip
Properties of your source files, including video, audio, image files (format, file size, where did you get it?): MTS
What devices are involved and their mode of connection?: NA
Project Properties (important): NA
Output format (file, DVD, VCD, SVCD): NA
Output Properties (cogwheel in lower left of burn screen): NA
PAL or NTSC: NA
Error Codes (if any): NONE
Product Version: VS X3 Pro
Re: Audio filter cannot be used
Post by Trevor Andrew »
Hi Link
Just tried and I cannot use the filter after split audio when using Mts/M2ts files.
I can however create a sound file Wav to replace the Mts audio file. I am then able to apply the filter.
I do not know if updates has altered this option
link_xue
motherboard: Intel
processor: Intel
ram: 1GB
Post by link_xue »
Hi Trevor,
Thank you so much for the heads up. I saved the sound clip as wav file and it works. :D
Kind regards,
Link
dmulford
processor: Core2 Quad
ram: 4.00
Video Card: NVIDIA GeForce GTX 550 Ti
sound_card: NVIDIA
Hard_Drive_Capacity: 1.5 TB
Post by dmulford »
Hello!
I am still having this trouble with X5 Pro--is there another way to handle this than re saving the audio files? I am often dealing with a large number of clips and this is clumsy to say the least.
And if not, then how do I go about saving the audio as a separate file in X5? :D
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
You cannot use audio filters on 5.1 channel audio, so you will have to convert it to stereo 2.0. To create an audio file in VideoStudio, use Share > Create Sound File.
