Hello,
I'm running Corel Videostudio Pro X2 on Windows XP. I haven't had any problems doing a straight video and using some inserted images. For the first time I've tried just to use images (18 of them) with a music score--no video at all. I set everything up at timed intervals for the images to appear at certain points in the score and it seems to be fine. However, when I do a full playback, the images begin to lag in the range of 1-2 seconds behind the score. When I scroll back over just a short little section of one image, they sync up again. It doesn't stay in sync for longer ranges (playing from beginning to end--about 3:30 total). I have tried rendering in HD and the same thing occurs. This is for Youtube. Any suggestions on how to fix this?
Thanks!
Images Lagging Behind Audio
gomesongs1
- motherboard: ASUSTeK Computer INC. M3A78-EM Rev X.0x
- processor: 2.70 gigahertz AMD Athlon 64 X2 Dual Core
- ram: 1792 MB
- Video Card: ATI Radeon HD 3200 Graphics [Display adapter]
- sound_card: ATI HDMI Audio
- Hard_Drive_Capacity: 250GB
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Re: Images Lagging Behind Audio
What is the audio file format?
MP3's can cause odd problems, try it with a wav file
http://www.myvideoproblems.com/Tutorial ... o_WAV.html
Welcome to the forum.
A bit strange, don’t think I have heard of this problem before.
Things to try….
1 / When you create the video file disable Smart Render. This is done from the save window-Options button.
2 / Render the images to a video file then add sound and render again.
Things to try….
gomesongs1
- ram: 1792 MB
Thank you both for the replies. I will give these options a try later on and report back.
Cheers!
Cheers!
Have transitions been inserted between the images? If so, that will changing the timing incrementally as you go along...
gomesongs1
- ram: 1792 MB
Thanks again for the replies to this issue.
Graham--it appears as if the mp3 was the problem. I tried it with a wav. file and all seems to be well.
Trevor--I will use your suggestions during rendering.
Ken--I've only used one transition but now that it appears to not be lagging, I might be able to insert a few more.
Thanks for the support, guys!
Terry
Terry
