Chapter Points not Transferring from the Edit mode
geno_je
operating_system: Vista Home Basic
motherboard: Asus Mother board
processor: Q6600
ram: 4GB
Video Card: GTS 8800
sound_card: intergrated
Hard_Drive_Capacity: 320
Post by geno_je »
Hello,
I am using Pro X3.
When I create a home movie and add chapter points through the edit mode, and then go to burn a DVD, the Chapter points that I created in the edit mode are not showing up in the Corel DVD Factory burning software.
I can re-add the chapter, but why would the chapters that I just added, not show up?
What is the point of having the options to add chapters in the edit mode, if this information was not transferrable to the burning process?
Thanks.
Re: Chapter Points not Transferring from the Edit mode
Post by Trevor Andrew »
Welcome to the forum
There has always been problems in using Chapter Points, for earlier versions you were able to add a project to the authoring program retaining the chapter points, but gave problems for some.
For X3 you have to complete the project by Share Create Video File, DVD will create an Mpeg 2 file suitable for burning a DVD. In creating this file the chapter points are lost.
Using DVD Movie Factory 7se you add the Mpeg2, here you can create the chapter points.
So ignore the chapter points in the editing stage.
