Greetings,
I have added some photos using the option "keep aspect ratio". However, when the project has been rendered to 16:9 it has stretched the photos. How can I force X2 to "keep aspect ratio"?
Cheers
David
keep aspect ratio for photos
dmz
- motherboard: ASUS ROG Strix Z390-I
- processor: Intel Gen 9 i7 9700K
- ram: 32GB
- Video Card: mobo onboard
- sound_card: mobo onboard
- Hard_Drive_Capacity: 6TB
- Corel programs: VS 2020
Re: keep aspect ratio for photos
Once again as in your other post you are using language which puzzles me - is your project set for 16:9 - are your photos 16:9
If the project is 16:9 and the photos are 16:9 then rendering to 16:9 will not cause distortion - if on the other hand you are putting indeterminate format photos into a 4:3 project and then rendering as 16:9 some distortion must occur.
Set your project properties for 16:9 and put you photos in using the keep aspect ratio option - yes if your photos are not 16:9 your photos will have black borders top/bottom and/or both sides - but unless your photos are a true 16:9 that is what must happen if you do not want distortion - you cannot fill the wide screen with them if they are not wide screen to start with..
Reason: spelling
Reason: spelling
Hi David
also
What are your project properties? (File-Project Properties.)
What options did you choose to render your project? Share Create Video File-?????
also
