Problems in activating PSPx3
johnfairweather
- motherboard: P5KPL-AM SE
- processor: Intel Core2 Quad CPU Q8300 2.50GHZ
- ram: 4GB
- Video Card: High Definition Audio Device
- sound_card: High Definition Audio Device
- Hard_Drive_Capacity: 500GB
This is a problem that I have been having since the 21st September, it is now 12th October - I have been in touch with Corel's Tech support but they can't seem to solve the problem.
In May 2010, I installed PSPx3 on to my Windows XP PC. In June 2010, I had my PC upgraded to Windows 7 (and installed Office 2010). When I re-installed PSPx3, I then got an 'Activate Now' message, with gave me 22 days left, though the program worked ok. Clicking on Activate, I got another message saying 'OK', but the 'Days Left' still continued downwards. When I tried to activate it by phone, the system displayed a blank 'Installation Code', so Tech support couldn't help me. The only solution Corel gives me, was to use their Clean-Up code and to re-install it under 'Admin' on my PC. This I have done, without the 'Activate Now' message going away and I am about to dive into the Registry to try again.
I have attached some screenshots.
Also Corel seems to be releasing new PSPx3 software/updates every few months, with a cost, I can't see why some of this can't be free. Also, it might be an idea for Corel to solve this problem, before new software is released. (Why call a new version 'Ultimate', when another new version comes out weeks later, this doesn't seem very good policy to me.)
I am a software engineer/tester (& website designer) by profession and these things do annoy me.
Reason: Images containing serial numbers deleted
Simone Corel UK
- Alludo
Re: Problems in activating PSPx3
@ johnfairweather
Please take out that screenshot with the serial number!
I'm going to send you an e-mail from our UK support
Simone
Simone
bpdavis
- motherboard: Gigabyte EP45-UD3LR
- processor: Intel Dual Core2
- Video Card: NVIDIA 460
- sound_card: SBLive
I am having exactly the same problem. I installed on Windows XP in July 2010, and upgraded to Windows 7. I get the same blank message box, and when entering the activation code that was given when I installed on XP, I get the following message:
The Activation Code you have provided is invalid. Please try again, or visit http://www.corel.com for information on contacting customer service.
I have a support ticket in progress with Corel, but so far the issue has not been resolved.
If it matters, I'm using Windows 7 64-bit.
I would really appreciate any help to resolve this issue.
Thanks,
Brian
Thanks,
Brian
caspia1
- ram: 16gb
- Hard_Drive_Capacity: 1Terrabit
- Monitor/Display Make & Model: twin hp displays
- Corel programs: Pro 2023 Ultimate
For what it´s worth I read somewhere that 64 bit does not work with X3. If I´m wrong I apologise.bpdavis wrote:Hi,
Thanks,
Brian
bpdavis
According to the Corel system information for PSPx3, http://www.corel.com/servlet/Satellite/ ... bview=tab6, 64 bit is supported. I was intrigued by your reply, so I checked it out. Granted, that is the Ultimate edition, but certainly the version I bought barely over three months ago would be also.caspia1 wrote:For what it´s worth I read somewhere that 64 bit does not work with X3. If I´m wrong I apologise.
- ram: 6 GB
- Corel programs: PSP: 8-2023
X3 does work with Windows 64-bit. Don't worry about that.
I can only imagine you've read that X3 is still only a 32-bit program, but those do still work with 64-bit Windows.
Or you've read comment from people making the assumption that they're using 64-bit Windows and that's what their problems are.
johnfairweather
- ram: 4GB
Simone,
Finally, I found time to install PSPx3 from the CD you sent me. It now works OK and the blank Activation page now does not appear.
I also did purchase your Ultimate add-ons.
John
John
bpdavis
John, I'm glad that you had success getting PSPx3 installed on Windows 7.johnfairweather wrote:Simone,
John
Simone, if there is any way you can offer me assistance, I would greatly appreciate it. I have yet to hear back from Corel's customer support ever since my initial question.
If it helps, my support reference number is 101025-000119.
Thanks,
Brian
johnfairweather
- ram: 4GB
Thanks Brian,
Incidentally, downloading the 'Ultimate add-ons' crashed my NTLWorld web mail server, though I think I installed them correctly. After a time, I got fed with the whole install business of PSPx3, their clean-out registry tool (in my opinion) doesn't clean out all of the corel registry.
John
John
bpdavis
Thanks for the heads up about the Ultimate upgrade. At this point, I fear I may be out $60. While the application worked very well under Windows XP, it simply will not activate under Windows 7 for me. I am really surprised that others have not had similar experiences. I'm also extremely disappointed in the lack of support as well. Until they fix this problem, I just cannot see me recommending this product to anyone using Windows 7. That is a shame since it is a decent tool.johnfairweather wrote:Thanks Brian,
John
ocwildlife
I have had reinstallation problems after using the removal tool, all the directions to successfully reinstall have not worked. [after giving up on crashes and deciding to reinstall] Won't accept serial numbers. Redoing it all after waiting for corel support reply. Still no luck. A shame, really, because I have been a 10 year fan of PSP. One more try at this tomorrow and then I am done with Corel. Too many hours expected of us here. Win7 compatibilities are a big problem also. Ridiculous for Corel to know of these problems and they not immediately allowing a password number to reinstall, not alone the time involved trying to jump through hoops for hours to get the program installed properly.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
@bpdavis - I have reported your reference number and our Customer Service may be in contact with you.
@ocwildlife - If you need assistance with the reinstallation process of your PSP X3, I suggest that you call our Customer Service Department from the number posted here, if needed they can do perform remote assistance.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
I have exactly the same problem: the activation fails with blank message and blank installation code, no proper support from Corel.
Attaching a log that has been sent to Corel, hopefully it gives some clues as to the reason of activation failures. The log is created in ..\Users\username\AppData\Local\Temp every time I try to activate.
Start time: 11/17/10 11:29:31
Module: C:\Program Files (x86)\Corel\Corel PaintShop Photo Pro\X3\PSPClassic\Corel Paint Shop Pro Photo.exe
11/17/10 11:29:32 MS::CP elapsed time: 0.772 seconds
11/17/10 11:29:32 ATE elapsed time: 0.000 seconds
11/17/10 11:29:33 VA elapsed time: 0.724 seconds
11/17/10 11:29:33 MD elapsed time: 0.318 seconds
11/17/10 11:29:33 In OnBeforeNavigate2 - URL:C:\Users\username\AppData\Roaming\Corel\Messages\540243425_217031\EN\MessageCache1\Workflow\container.htm
11/17/10 11:29:34 In OnNavigateComplete2 - URL:C:\Users\username\AppData\Roaming\Corel\Messages\540243425_217031\EN\MessageCache1\Workflow\container.htm
11/17/10 11:29:34 In OnBeforeNavigate2 - URL:about:blank
11/17/10 11:29:34 In OnNavigateComplete2 - URL:about:blank
11/17/10 11:29:34 OnDocumentComplete is called for URL:about:blank
11/17/10 11:29:34 In OnBeforeNavigate2 - URL:pcucmd://FrameLoaded/
11/17/10 11:29:34 OnDocumentComplete is called for URL:C:\Users\username\AppData\Roaming\Corel\Messages\540243425_217031\EN\MessageCache1\Workflow\container.htm
11/17/10 11:29:34 AdjustWizardSize - called : 0
11/17/10 11:29:34 In OnBeforeNavigate2 - URL:pcucmd://ContainerLoaded/
11/17/10 11:29:34 In OnBeforeNavigate2 - URL:file:///C:/Users/username/AppData/Roaming/Corel/Messages/540243425_217031/EN/MessageCache1/Workflow/1205358652437/body.htm?ShowCounter=yes&NumDays=25&Status=2&ST=1&licenseid=540243425&SourceID=217031&lang=EN&RTO=8&TotalDays=30&isregistered=1®type=1
11/17/10 11:29:34 In SetFrameElementSrc - starting the timeout timer for strURL=C:\Users\username\AppData\Roaming\Corel\Messages\540243425_217031\EN\MessageCache1\Workflow\1205358652437\body.htm?ShowCounter=yes&NumDays=25&Status=2&ST=1&licenseid=540243425&SourceID=217031&lang=EN&RTO=8&TotalDays=30&isregistered=1®type=1
11/17/10 11:29:34 In OnNavigateComplete2 - URL:file:///C:/Users/username/AppData/Roaming/Corel/Messages/540243425_217031/EN/MessageCache1/Workflow/1205358652437/body.htm?ShowCounter=yes&NumDays=25&Status=2&ST=1&licenseid=540243425&SourceID=217031&lang=EN&RTO=8&TotalDays=30&isregistered=1®type=1
11/17/10 11:29:34 OnDocumentComplete is called for URL:file:///C:/Users/username/AppData/Roaming/Corel/Messages/540243425_217031/EN/MessageCache1/Workflow/1205358652437/body.htm?ShowCounter=yes&NumDays=25&Status=2&ST=1&licenseid=540243425&SourceID=217031&lang=EN&RTO=8&TotalDays=30&isregistered=1®type=1
11/17/10 11:29:34 AdjustWizardSize - called : 2
11/17/10 11:29:34 In OnBeforeNavigate2 - URL:pcucmd://FrameDataLoaded/
11/17/10 11:29:34 In OnPCUCommand (PCU_COMMAND_FRAMEDATALOADED) - Load completed successfully
11/17/10 11:29:36 In OnBeforeNavigate2 - URL:pcucmd://CallScriptFunc/?funcname=activate
11/17/10 11:29:36 In OnBeforeNavigate2 - URL:pcucmd://Activate/?admin=yes
11/17/10 11:29:37 PCUError:23:
11/17/10 11:29:38 In OnBeforeNavigate2 - URL:pcucmd://Next/?condition=true
11/17/10 11:29:38 OnPCUCommand - Condition not met, not executing the command:23
11/17/10 11:29:39 IP_UI elapsed time: 6.273 seconds
BTW, I am a software engineer, too. I agree that all these problems are really annoying.
Windows 7 Enterprise 64-bit
JusticeAA
- motherboard: Gateway
- processor: i7 860
- Video Card: ATI HD5770
- sound_card: Soundblaster X-fi
- Hard_Drive_Capacity: 1TB
I am sorry to say that I had the same problem. Here is what I did to fix it with Win7 x64 Home Edition
1. Uninstall ALL Corel software (I only had Painter X which I have a disk for so it was no big deal)
2. Make sure that you can see hidden files and folders
3. Open your system drive
4. Search for "Corel"
5. In the search results, find the FOLDERS named Corel (There should be some in the user directories under AppData and ProgramData and maybe in TEMP
6. Delete ALL of the Corel FOLDERS
7. Reinstall PSPx3
After I did this it started without a problem, hope this helps.
7. Reinstall PSPx3
Thank you! As far as I remember I tried removing everything Corel from my PC, both filesystem and registry, but it didn't to work for me :(JusticeAA wrote:I am sorry to say that I had the same problem. Here is what I did to fix it with Win7 x64 Home Edition
7. Reinstall PSPx3
Anyway, Corel already sent me an installation disk so that I don't have to activate on-line.
