I am using VS Pro X3.
I have a .mov file in 16:9 ratio. I need to add a picture to the front of the movie so that this image appears in the player I am using when the movie is loaded and ready to play.
EVERY time I try to create the new movie, the movie aspect is reformatted and I get black bars across the top and bottom of my movie. I have been everything I can find in the program - using custom formats and defining the exact dimensions. I must have tried this over a dozen times looking for something stupid that I am missing but I can not figure this out.
The original file is quicktime (.mov) 960X540. If I play this file in my player (its a flash player) it plays clean in the 16:9 aspect with no black borders. This should NOT be a mystery, but if someone can tell me what settings to use. I do not care whether the file is .mov, mp4, or flv. The player supports all of these (and a few more common types). This will be web hosted so I am concerned about file size. Step one for me is to get VS to create a movie file in the appropriate aspect ratio without black bars!!!
can't keep VS from changing the aspect ratio
Re: can't keep VS from changing the aspect ratio
Welcome to the forums..
You should be able to create a MOV video file, and use the properties of your clip.
- Go to Share>Create Video File, Select Custom
- In the Create Video File dialog window, change the Save as type to Quicktime Movie Files
- Click the Options button
- In the Video Save Options dialog, click on the General tab
- On the General tab, under Frame size click on the radial button for User-defined, enter the frame size (960 x 540)
- Adjust other settings to suit your needs, then when finished clicking OK will close the dialog.
- Provide a name for your video file, click Save. VS should now create a video file, using those settings.
