Colour washing out
Colour washing out
I have captured a high quality Hi-8 video tape to a 15GB AVI file. The colour on the preview window during capture was excellent - good depth, as Hi-8 tape should be. I then rendered it at quality setting 100% and 9500Kb bit rate. It was a long shot that MF4 would actually do this without producing sizing or other error messages, but to my absolute surpise it produced a nice 4GB ISO file. Burning to DVD using Nero was OK, but while the DVD image is very high resolution the colour seems to have been washed out a fair bit. Has anyone else had this problem? Thanks.
Did you have a setting for "7.5 IRE" or "SETUP" on your preview during the conversion (on your camcorder)?
I suspect you have added 7.5 setup, and then your DVD Player might be doing it again -- this can result in "washed out" video.
Also, 9500kbps is OVERKILL considering the source video. I think 6000kbps should be fine given your hi8-converted-to-dv video.
George
what make and model number is your camcorder?
did you apply any auto-enchance filters or color correction to your video (in MF or any other software)?
DV Video usually looks darker on your computer monitor, but plays fine when viewed on a TV. If you adjusted your video to look "normal" (i.e. not dark anymore) on your computer, then that would explain why it would look "brighter" on a TV.
George
Thanks to GeorgeW I can now view my ISO images. They are perfectly colourful. The colour wash out must then be due to either Nero, which I use to burn the ISO to disk, or the disks themselves. I trust Nero, so the only conclusion is that the TDK blanks I use are not as good as they used to be. 12 months ago, a 4x TDK DVD blank and case cost A$5. Now an 8x costs A$.80 cents. I believe that in an attempt to counter a flood of cheap Chinese imports, TDK has matched their price but also matched their quality, which could be very poor. Can anyone else verify this? If so, is there still a genuine quality DVD blank out there? If not, what the hell is happening to the world when all you can buy is cheap and nasty???
