How to rotate 16:9 video
dogron
Post by dogron »
Am still using Videostudio 9, so if the problem below is solved in a later version, please let me know.
Am trying to rotate a MPG video taken with an original aspect ratio of 16:9 in portrait mode ie long side vertical.
The video loads into Videostudio fine, ie the image is sideways-on as expected and there are the black bars at top and bottom in the edit window as is usual for 16:9 videos.
If I use the rotate button, this does rotate the video, but there are now black bars down the left/right sides as well as top and bottom, and the viewable image looks 4:3 (?) - it is flattened ie people look short and fat.
Is there a particular project property/create video setting I need to set. I don't understand the settings - I'ver tried things like 'non-square pixel rendering' without knowing what to expect - but nothing so far seems to work.
Any help - much appreciated
Ron
Re: How to rotate 16:9 video
Post by BrianCee »
I notice you haven't been around since December 2005 - so 'Welcome Back' :)
If you take a video and rotate it through 90 degrees you are always going to get black bars down each side - because of the video format - no matter if 16:9 or 4:3 - there is nothing you can do about that .
The black bars top and bottom are I suspect entirely due to the way videos are viewed in the preview window - if you have your project properties set to 16:9 you will always see black bars top and bottom because basically the preview window is a 4:3 format - when you view your video on a true 16:9 screen it should not have black bars top and bottom - but I'm afraid you are stuck with bars each side.
You can probably get rid of the 'squashed ' distortion your seeing - in the top left corner of VS9 right under the tab with the project name on there are two tabs - 'Video' and 'Attributes' - Video is the default so click on Attributes, now down the left side you will see a box with 'Distort Clip' next to it - click to tick the box.
In the preview screen a box with yellow markers will appear - with your mouse cursor move the markers up the sides out a little to get the image you want.
Moral - always keep your video camera the right way round.
It's a long time since I opened up VS9 - nice to see the young lady on the splash screen again - she's probably married with children by now
dogron
Post by dogron »
:D Thanks very much for the very helpful reply, Brian. :D
Thanks - I hadn't realised, till I tried looking on the forum yesterday, that it was quite that long. :o
VS9 has so far done all I've wanted to do - fairly simple editing and titling - and because I had problems in familiarising myself with the new options with my last upgrade (from VS6 to VS9 - as in my last post), I've decided to stick with VS9 for the time being.
This is what I was after, and it works perfectly for me - so thanks again. "Distort" was one of the features I thought I'd never have a need to use, so was unfamiliar with what it could do - just goes to show, you should never say never :lol:
Pity there isn't some sort of clickable setting which would allow consistent "distortion" from clip to clip.
Basically the scene is portrait - (I'm trying to video a couple dancing). It seemed easier to video with the camera turned round than take regular landscape videos and then zoom/crop them to get the image I wanted. Plus, being indoors, there wasn't enough room to get all the content I wanted in in landscape mode - the camera had to be on its widest setting as it was.
Another reason I didn't upgrade :)
Anyway - thanks again. All best.
Ron
Post by Trevor Andrew »
Using the overlay track will allow you to distort the frame of the first clip, then Copy and Paste the Attributes to the remaining clips.
dogron
Post by dogron »
Thanks Trevor - works a treat :D
Also thanks for including the links to your user guide - have only just had a quick scan, but already found them very informative.
Regards
Ron
