trevor andrew wrote: I did mention that I normally load my clips to the timeline and not the library.
Don’t get me wrong, I do use the library but maybe in a strange way.
Having some 250 clips in the timeline, in some cases many may need deleting.
I drag them to the library, delete from the timeline and continue editing, eventually I end up with the library full of unwanted clips, they can be removed from the hard drive, the library gives me that option.
Hi Trevor
I have some new information now. As I told earlier I will want to test importing the clips directly into the timeline/storyboard. I did that yesterday evening. I kept my previously loaded clips in the two libraries I established for those.
But then I imported an other set of approx 150 clips directly into the storyboard. And guess what happened: it imported them so quick, in a few seconds all of them, from the external hard disk via USB interface!! Also the scrolling through the story board works with no hick ups and the scroll bar works smoothly.
When I scroll through the clips in the library then the scroll bar still is jerky.
To me, it seems that Corel has a challenge with the library. I only do not know what's the reason.
Anyway, may be I start to use your preferred method and import in future all clips directly into the storyboard instead of making individual libraries. And if one does a download from the camera already into clear defined subject folders to the harddisk then some sorting for the story is already done and one can import only that subfolder to the storyboard and work on the particular theme.
I have not yet informed Corel support on this topic. Should we perhaps do that?
Best regards
Hanspeter
