que points
bob816
- motherboard: gateway
- processor: AMD quad 2.8GHz
- Video Card: ATI HD4650
- sound_card: Realtek HD audio
- Hard_Drive_Capacity: 3TB
que points
What is the difference between a que point and a chapter point?
Re: que points
A cue point is simply a spot you want to mark so that you can easily find it in relation to inserting something else. For instance, if you want to insert a dramatic piece of background music at a particular spot, you could insert a cue point where you would later start the music. Or you could use it to indicate where an overlay on another track might later be inserted. A chapter point, on the other hand, relates to the final DVD or disc, and is what your remote control on your player looks for if you want to jump along in a video as you are playing it back.
bob816
Re: que points
Thanks for the answer. The manual doesn't even have cue in the glossary.
I read one post stated that the chapter point put in in Video Studio did not transfer to his Bluray. Is that still a problem? I did not see a definitive answer. ( I have not tried putting chapters in the project yet. I usually do it in the burner software but would rather do it in the project if it works)
Re: que points
To be honest, I don 't know the answer to the question about chapter points inserted in the Editor. I have always inserted chapters as part of the menu-building in the burning process too, and it certainly always works there!
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Re: que points
This issue was raised many moons ago,I am sure there were problems putting chapters in the editor(mainly not working!)A search may find the posts
concerned.................Ken
