How to put UNCOMPRESED AVI file in MediaStudio Pro timeline
anny
motherboard: I have PORTATIVE COMPUTER
processor: 1.30 gigahertz Intel Celeron M -PortativeComputer
ram: 32GB
Video Card: SoundMAX Integrated Digital Audio
sound_card: SoundMAX Integrated Digital Audio
Hard_Drive_Capacity: 40.00 Giga
Post by anny »
Hello!
I would like to know, is it possible to put in timeline UNCOMPRESSED AVI video file, what is made in ADOBE PREMIERE PRO. I can put in MediaStudio Pro COMPRESSED AVI video file, but it do not work the same with UNCOMPRESSED AVI video file. Maybe it will be possible, if it will be special plug in downloaded?
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Re: How to put UNCOMPRESED AVI file in MediaStudio Pro time
Post by skier-hughes »
Could you check your pc specs, you say you have a 1.3g processor, but 32gb of ram, and 40gb of hard drive. Is it a notebook or desktop.
An uncompressed avi file will take up approx 60gb of hdd space for each hour, so unless the file is only matter of a minute or so long you are going to have dificulty with space.
dv.avi is the most common avi file and can be used in any video editing app, this only takes up 13gb per hour, so you are much more likely to be able to use this sort of file on your pc.
anny
ram: 32GB
Post by anny »
skier-hughes wrote:Could you check your pc specs, you say you have a 1.3g processor, but 32gb of ram, and 40gb of hard drive. Is it a notebook or desktop.
Video is 2 min long. When I dubble click on timeline and shoosing video file, than it works just with COMPRESSED AVI, but not with UNCOMPRESSED AVI. I have portative computer.
Gorf
Post by Gorf »
Uncompressed video works fine on the MSP timeline, without the need for extra plugins or codecs. If your uncompressed AVI is not being recognised, it's likely that either
  • it's not really uncompressed
  • its FourCC code is wrong
As skier says, your system specs look a bit odd. 32GB memory looks out of place with the o/s, HDD space and processor, so I'm guessing it should read 32MB, which is still painfully low for XP. If your uncompressed AVI is being read from an external drive, that will also result in a pretty major bottleneck depending on
  • the bitrate of the video in the file (see below)
  • the USB (or whatever) standard used for the connection
skier-hughes wrote:...An uncompressed avi file will take up approx 60gb of hdd space for each hour...
Where did that figure come from??? The file size depends on more than just duration - colour depth, framerate and resolution are all factors.
One hour of CIF resolution RGB at 15fps is 15.3 GB
One hour of SD video is 104.3 GB
(SD is RGB 720x576 @ 25fps or 720x480 @30fps, makes no difference to bitrate)
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
Basically without going into too much detail I was trying to let the OP understand an uncompressed video would generally be a huge file size, which from my memory of working with adobe premiere back in v6.5 was a round the 60gb per hour size. I don't think they'd understand the ins and outs of the various varieties that were available.
