How to Print Dates on Pictures in Paintshop Photo Pro X3
explorerfound
motherboard: Asus M2N-SLI Deluxe
processor: AMD Phenom II X4 945 3.0 GHs 8MB cache Socket AM3
ram: 4 GB
Video Card: eVGA e-GeForce 7600 GT KO 256MB PCI-E Dual DVI
sound_card: onboard 8-channel 7.1 audio
Hard_Drive_Capacity: 1.5 TB
Post by explorerfound »
How would I go about im-printing the date the picture was taken (from the EXIF or image metadata) onto the image so that the photo displays that date, and it is also displayed on the printed image? I am using Corel Paintshop Photo Pro X3. Thanks for your help, I am new to the product & have delved into the forums & knowledgebase with no luck (just yet).
Update regarding this Inquiry: I received a reply to the above inquiry from Support (in the last 2 days), where they state - "Kindly be informed that you can only show the EXIF camera model , exposure and aperture of the image. EXIF Date is not included." Responding to their reply, I asked if this inquiry could be updated on the Corel User Web Boards, to which they recommended that I post it here. (A search revealed that this topic had not been raised & I was unable to locate it in the User Manuals either.) Support advised: "Yes, you may add this information to the the forum. Also, by including this topic, you may encounter veteran users who can tweak the scripts and find a solution to your queries."
At present, my knowledge of the PPP X3 is somewhat limited; however, I wonder if one work-around would be to insert the date as a viewable watermark onto an image layer? All the same, I'd prefer a more automatic / integrated process that ideally could be toggled to insert the date to appear on the photo when required.
Thanks, any suggestions & creative work-arounds are gratefully appreciated.
Cheers, Spencer
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Re: How to Print Dates on Pictures in Paintshop Photo Pro X3
Post by Trev Bowden »
http://www.trevorbowden.co.uk/EXIFCaptioning_v2.zip
That adds date and some other data to an image Exposure ect on the lower corner but can be changed Use the robins version and you will find Instructions for editing included
explorerfound
ram: 4 GB
Hi Trev,
By golly this is exactly what I need! Thank you so very much. Today, I was *finally* able to re-visit your script solution with the original problem. So, I loaded up your script & it works very well.
I have just one further concern that I'm in the process of checking further into ... I'd like to add the time that the picture was taken, just following the date as it appears on Line 3.
Although I'm not too terribly familiar with script editing, your instructions are quite good & I believe I should be able to add the time component under the included instructions - "Customisation - Line 3".
Thank you for the tremendous assist! This will prove v. helpful with a project that I am working on.
Cheers & Best Regards,
Spencer
UPDATE: I have now (next day) met with complete success so that the date and time correctly display! Thank you!
