PNG transparency not preserved
vincenth
motherboard: Dell Inc. 0RD203
processor: 3.00 gigahertz Intel Pentium 4
ram: 2.5GB
Video Card: ASUS Extreme AX300 Series
sound_card: SigmaTel High Definition Audio CODEC
Hard_Drive_Capacity: 300GB
Post by vincenth »
I use PSP to modify PNG image files. For those images containing areas of transparency, when I attempt to resave the image (as a PNG file), I get a message that it must be saved in a "merged" format. I select Yes/Continue, and the resulting file is white in the areas that were transparent.
What options must I select to preserve transparency in PNG files?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: PNG transparency not preserved
Post by LeviFiction »
You should only have to do this once and the settings will stick until you want to change them.
Go to File->Export->PNG Optimizer
Go ahead and select the transparency tab and select how you want Paint Shop Pro to define the transparency. You can use specific colors or you can have it use the current transparent areas in the image.
When you hit Okay it'll go ahead and open the "Save Copy As" dialog. And you can save out from there. Once you go to save as a PNG again it'll use the last known settings for the optimizer by default so you won't have to use the optimizer again yourself.
The other way is when inside the Save As or Save Copy As dialogs is to go to the bottom right-hand corner and select the Run Optimizer button in there. It'll open the same dialog and allow you to edit the same settings.
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
Use the PNG Optimizer as LeviFiction has suggested and you will retain transparency, but you will still be saving a merged image... i.e. one that is a single raster layer. If you need to retain layers or vector objects you will need to save a PSPIMAGE copy as well as the PNG.
Tim Morrison
C-Tech Volunteer
