Do I need ti install the service packs?
allanhobbs
- motherboard: Gigabyte 965P-S3
- processor: 2.40 gigahertz Intel Core 2 Duo
- ram: 3GB
- Video Card: NVIDIA GeForce 9400 GT
- Hard_Drive_Capacity: 1GB
I just purchased PSP Photo X3 and noticed there are 2 service packs available.
Are these service packs already included in the download I did today or do I need to install either or both of them?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Do I need ti install the service packs?
Run "Check for Updates" inside of PSP and let it decide.
But if you really want to know, then that depends. When PSPX3 starts up what is number in the lower right-corner of the splash screen?
If the number is 13.2.0.35 then you're good to go. If it's something else then you need the patches.
EDIT: Corrected the number above, small typo it said 15 when it should have said 35. My bad.
jaxman
- motherboard: Dell Inc. 0C7195
- processor: 2.80 gigahertz Intel Pentium 4
- ram: 3GB
- Video Card: NVIDIA GeForce 9500 GT
- sound_card: SB Audigy
- Hard_Drive_Capacity: 250 GB
My splash screen shows 13.2.0.35.
allanhobbs
- ram: 3GB
My splash screen also shows 13.2.0.35
GeorgK13
- motherboard: Intel
- processor: Pentium 4 3.2 Mhz
- ram: 4 MB
- Video Card: NVidia
Hellow there.
My version is 13.2.1.7
Do I need to install patches? And what number, 1 or 2?
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Hello everyone,
I'm Abiel from Corel Support. Like what LeviFiction said, if your version number is 13.2.0.35 then you're good to go. But if you like to make sure if you have the updated software, then you can click on HELP > CHECK FOR UPDATES or you can manually download the updates from http://www.corel.com/servlet/Satellite/ ... 9872271743.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Abiel you may want to clarify if they need to install the first patch then the second of if the second includes the first patch in it. That question hasn't been answered yet.
Regards, Dan
i9cripple
- motherboard: ASRock A780GMH 128M
- processor: 3.00 gigahertz AMD Phenom II X4 940
- Video Card: NVIDIA GeForce GTS 450 [Display adapter] PHILIPS [
- sound_card: VIA High Definition Audio
- Monitor/Display Make & Model: Philips LCD TV 40PFL5505D
I have the boxed version and it reports as being version 13.2.1.7, but after manually installing the patches up to service pack 4, the version number is only 13.2.1.20, so I suppose I should uninstall/re-install the original disc version, right?
- ram: 6 GB
13.2.1.20 > 13.2.1.7
So....no. You are all up to date.
Well mostly, there is a special patch for a bug regarding losing pixels after merging down or defloating selections and things like that. But it doesn't change the version number at all since it's not the official fifth patch.
i9cripple
Oh, ok. I didn't know the version numbers worked that way.
MToiviainen
- motherboard: ASUS EAH5450 series
- processor: AMD Athlon II X4 645
- ram: 4 GB
- Hard_Drive_Capacity: 750 GB
- Monitor/Display Make & Model: LG IPS246V 23"
For the heaven sake, could Corel make a more mess on service packs??? Have you counted how many questions in this forum related to sp:s?
Did I understand right: if I have box-installed PSPX3 version 13.2.1.20 (or higher) I do NOT need to install service packs 1-4? (CHECK FOR UPDATES doesn't find any updates).
- ram: 6 GB
Box or download doesn't matter. If the version number is 13.2.1.20 then you have all four service packs installed.
If you want to get rid of the bug where pixels are lost when performing a merge down or defloating a selection and so on there is a special beta fifth patch, in other words you have to find it, that you can install. This does not change the version number at all, so if you didn't install it manually you don't have it.
Patch #5 - technically
Again it's not the truth fifth patch, assuming its coming at all, but it does help a little.
