replacing sequence
yotta
motherboard: msc20
processor: intel
ram: 2GB
Video Card: geforce
sound_card: integred
Hard_Drive_Capacity: 250GB
replacing sequence
Post by yotta »
i am looking to how replace a sequence in video with an other sequence or image?
thank you
NB: i am using Corel videostudio X3
Re: replacing sequence
Post by BrianCee »
Put the video in the timeline
select the 'Edit' stage (tab at top)
click on the video to highlight it - move timeline cursor to begining of piece to be removed - use scissor tool to cut video
Move cursor to the end of the piece to be removed - again use the scissor tool to cut the video
click on the piece of video to be removed so that it is highlighted - hit the delete key - video gone
from your library drag and drop the new piece of video over the join - there will not be a space but the video will move apart when you drop the new piece in.
Click on the 'Share' tab at top - down page select - "Create Video File" - follow procedure to make a new file with the new piece of video in it.
There are other methods - this is the one I prefer - any further questions please ask.
yotta
motherboard: msc20
processor: intel
ram: 2GB
Video Card: geforce
Post by yotta »
thank you for the accurate instruction.
but i would like to replace the sequence and to keep the voice , like if when u won't see the sequence but to hid here(dont show it to the watcher), and i would like to put during that sequence a picture or video ?
Post by Black Lab »
In that case you want to use the Split Audio function on the first clip. That will put the audio portion of it in the audio track.
Post by BrianCee »
OR - there's always more than one way of doing things.
leave the video and sound in the top track exactly as it is - then put the new piece of video in one of the overlay tracks at the position you do not want to see the original video - set the option to fill the screen - mute the sound of the overlay (new) piece of video - then Share >> Create Video File to render a new video file.
Anything in the overlay track appears on screen instead of the top track
Post by Black Lab »
That's always been a bug-a-boo with me. The tracks are upside down! The overlay tracks should appear above the video track. I think doing so would make it easier to "see" (i.e. understand) how it works.
MikeA
ram: 16Gb
Video Card: NVidia GTX 460
sound_card: Integrated
Hard_Drive_Capacity: 3 Tb
Monitor/Display Make & Model: LG Flatron
Post by MikeA »
That's always been a bug-a-boo with me. The tracks are upside down! The overlay tracks should appear above the video track. I think doing so would make it easier to "see" (i.e. understand) how it works.[/quote]
Not if you're Australian.
Post by Black Lab »
:lol:
Yes, and your toilets flush backwards too!
