Mp4 720 good quality?
Auser
- motherboard: Gigatebyte
- processor: Intel
- Video Card: Radeon HD7970
- sound_card: AU8830A2
- Hard_Drive_Capacity: 100
When I Create Video File/MPeg4HD - the output looks fine, but the output is 1920x1080, I need 1280x720 - and since there doesn't appear to be a pre configured 1280x720 template i tried setting one up myself.
BUT, the output looks very bad. Now I know 1280x720 is smaller than 1920x1080, but that doesn't account for it, its like it rendered in 256 colors or something (in some areas), any tips on getting this better?
The world would be easier if people were easier.
Re: Mp4 720 good quality?
Try a higher bitrate (higher bitrate = less compression = bigger file = better quality.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Auser
- processor: Intel
I can't go higher the program prevents it.DVDDoug wrote:Try a higher bitrate (higher bitrate = less compression = bigger file = better quality.)
If I render with their preset HD MP4 the file is
9265 kbps, 1920x1080, 30 fps, AVC (NTSC) (Main@L4.0)(CABAC / 2 ref frames)
(Which is a bit odd since I generally got PAL templates)
When I define a template in the Make Movie Templates manager, I go with H.264-MAIN - at 20000 kbps (I can't go higher than 20000), and this produces this:
9557 Kbps, 1280x720, 25 fps, AVC (PAL) (Main@L4.1) (CABAC/2 ref frames)
And that render has areas which seem to degrade into 256 colors (slight exaggeration but it think it describes it)
Auser
- processor: Intel
Several rendered pieces in 1280x720 24 bits, stored in a lossless codec.trevor andrew wrote:Hi
What are the properties of your original video file?
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
rendered from what?
Which lossless codec?
Auser
What is the source of your video files, what type of camera?
Please add an original video file to the timeline, right click and select properties.
What are they?
Now what are you trying to make with these files?
A standard DVD
A HD Blu-ray
A video file for the internet/you-tube
If we knew just what you were trying to do we could probably be more constructive.
What are they?
A standard DVD
A HD Blu-ray
Auser
- processor: Intel
Why does it matter?skier-hughes wrote:rendered from what?
Auser
- processor: Intel
I don't think you have the competence to help here. What does it matter what they are? I'm talking about the output from Videostudio pro - where the output in 1920x1080 looks fine but the 1280x720 output does not (which is curious since the input is 1280x720).trevor andrew wrote: Please add an original video file to the timeline, right click and select properties.
What are they?
As I wrote in the first message, I'm trying to make an MP4 file, at 1280x720. That means, not a DVD, not a Blu ray. Not a youtube movie. An MP4 file, at 1280x720 which doesn't screw up the colors.trevor andrew wrote: Now what are you trying to make with these files?
A standard DVD
A HD Blu-ray
I doubt it by now. I'm unsubscribing from this thread, and going to assume its a bug in the program.trevor andrew wrote: If we knew just what you were trying to do we could probably be more constructive.
I'll have see if i can output to a lossless format and have another program render it to the required resolution.
Thanks.
skier-hughes
- Microsoft MVP
- ram: 4GB
Because you asked for help and in order to do that we need to know certain things, but as you are obviously unwillingy to help yourself, I think you'll find everyone else will be as well, particularly as you seem to know more than all of us anyway.Auser wrote:Why does it matter?skier-hughes wrote:rendered from what?
