ATI HD3000 Series and WinDVD Pro 10
Moderator: lata
Kraster
Post by Kraster »
Are these GPUs supported by WinDVD Pro 10?
My ATI HD3450 was supported by WinDVD Pro 9 ... but on the requirements page for WinDVD Pro 10 it lists "AMD M7X and above" for ATI GPUs.
I ask because when I play a DVD through WinDVD 10 I see ~10% CPU usage and ~20% GPU usage in CCC. But when I play a Bluray I see ~90% CPU usage and ~3% GPU usage in CCC. What the heck?!
Defending Lazy.
nepenthe
motherboard: Gigabyte GA-P55A-UD3P
processor: i-7 860
ram: 16 GB
Video Card: Gigabyte GeForce GTX 470 SOC
sound_card: onboard Realtec audio
Hard_Drive_Capacity: 600 GB
Monitor/Display Make & Model: NEC MultiSync EA192M
Re: ATI HD3000 Series and WinDVD Pro 10
Post by nepenthe »
Kraster -
Excessive CPU usage may be due to background tasks:
http://bit.ly/b32Rx9
I suggest that you identify all running applications that load at boot. As you probably know, you can select automatic, manual, or disabled for Windows services. So check the Services list, sort by auto/manual/disabled, and identify all processes that have started. Those processes under auto that haven't started can be safely switched to manual. Check out the following TechRepublic posting regarding services that can be disabled:
http://bit.ly/cAULun
If your operating system doesn't include MS Config, you can easily block the launching of background tasks at boot with Spybot Search & Destroy (freeware):
http://bit.ly/MUhy
Once installed, open Spybot, click Tools>System Startup and remove the checkmark before processes that you don't want loading at boot. If you're sufficiently brave to use the registry editor [C:\Windows\System32\regedt32], you will find the list of startup processes under HKLM/Software/Microsoft/Windows/CurrentVersion/Run. Unlike Spybot Search and Destroy, deleting startup entries from the registry editor is not reversible, so be sure to export deleted subkeys for subsequent retrieval if necessary.
nepenthe
Rob717
motherboard: Intel DP45SG Intel P45 Express Chipset
processor: Intel Core 2 Quad Q 9550
ram: 8 GB
Video Card: ATI Radeon 4870 1GB
sound_card: On-board
Hard_Drive_Capacity: 2 TB
Post by Rob717 »
The ATI HD3000 series is supported, which version of Windows are you using?
Kraster
Post by Kraster »
Rob717 wrote:The ATI HD3000 series is supported, which version of Windows are you using?
Win7 32bit
Defending Lazy.
