Project Properties - How to Set Custom Values?
jmone
motherboard: ASUS P8Z77-VPro
processor: i7 3770K OC
Video Card: ASUS GTX660 OC
sound_card: FiiO E10
Hard_Drive_Capacity: 60TB
Post by jmone »
How do you set the Project Properties to say 1920 x 1080 x 24p in X3? The Project Properties option only lets you select common DVD and DV settings......
From what I remember the work around in earlier version of VS to let you set the Project Properties to something other than the limited DVD/DV defaults was to add a clip with the desired specs and VS would ask if it wanted to set the Project Properties to match....but this does not seem to work in X3 either!
Nathan
jmone
Re: Project Properties - How to Set Custom Values?
Post by jmone »
I found that if I open an old HDV VSP template I had it unlocked some more options for Refresh Rate and Frame Sizes but you still can not select compressions other than DV / MPG
