I contacted Corel Tech Support over what I believe to be high CPU usage when running WinDVD2010 Pro. When I ran WinDVD9 under Vista32 on the same hardware, CPU usage was significantly less then what I see now, more in the realm of 30-50%. Tech Support responded that I should call in and pay for an answer, so I thought I'd poll the community instead.
Please list the following specs and what you see in your resource monitor [min - max]% when playing a Bluray disc.
WinDVD2010 Pro v10.0.5.536.113375
Windows 7 32bit
ATI Radeon HD3450, drivers v10.8
Core 2 Duo 2.2GHz
2GB RAM
CPU Usage 70-85%
Thanks!
FYI, Tech Support did write back and tell me that I should install the latest ATI drivers (duh) as well as the Microsoft Visual C++ 2010 Redistributable Package (x86) and the Direct X Resdistributable package (June 2010). Links are below. I did this and it didn't really change much, but it also made me wonder why they'd suggest installing these packages when their own software documentation or installation procedure doesn't mention either. Does anyone have any experience with these?
http://www.microsoft.com/downloads/deta ... laylang=en
http://www.microsoft.com/downloads/deta ... ceb6d8fa8d
WinDVD 2010 Pro CPU Usage Poll
Moderator: lata
Defending Lazy.
nepenthe
- motherboard: Gigabyte GA-P55A-UD3P
- processor: i-7 860
- ram: 16 GB
- Video Card: Gigabyte GeForce GTX 470 SOC
- sound_card: onboard Realtec audio
- Hard_Drive_Capacity: 600 GB
- Monitor/Display Make & Model: NEC MultiSync EA192M
Re: WinDVD 2010 Pro CPU Usage Poll
Kraster -
WinDVD Pro 2010 does usurp considerable memory resources (123MB on my machine) but only 1-2% of CPU resources:
I-7 860 CPU (running at default 2.8GHz)
OCZ DDR3 1333MHz 4x2GB (8GB total physical memory)
Gigabyte GA-P55A-UDP3 (rev 1.0) mainboard
EVGA GeForce GTX 260 GPU
WD 'Velociraptor' 300GB HDD
Windows XP Pro 64-bit OS
nepenthe
nepenthe
37 views and 1 response? That's not much of a poll! C'mon people, post some numbers!
Defending Lazy.
lesterf1020
- motherboard: ASUS P8P67 DELUXE
- processor: Intel Core i7-2600
- Video Card: Amd HD 6970
- sound_card: Soundblaster X-fi Titanium
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Acer AL2216W & Samsung PX2370
Well WINDVD 2010 pro uses 221MB of ram on my system and 5% CPU without all2hd and 20% using ALL2HD
Asus Commando motherboard
intel Q9550 Processor
6GB OCZ DDR2 ram
AMD HD 5870 512MB Video card
6GB OCZ DDR2 ram
"History does not repeat itself. But it does rhyme!"
Rob717
- motherboard: Intel DP45SG Intel P45 Express Chipset
- processor: Intel Core 2 Quad Q 9550
- ram: 8 GB
- Video Card: ATI Radeon 4870 1GB
- sound_card: On-board
- Hard_Drive_Capacity: 2 TB
Kraster wrote:I contacted Corel Tech Support over what I believe to be high CPU usage when running WinDVD2010 Pro. When I ran WinDVD9 under Vista32 on the same hardware, CPU usage was significantly less then what I see now, more in the realm of 30-50%. Tech Support responded that I should call in and pay for an answer, so I thought I'd poll the community instead.
Windows 7 32bit
Core 2 Duo 2.2GHz
2GB RAM
CPU Usage 70-85%
Thanks!
The CPU usage will depend, do you mean WinDVD just open not playing a movie, Playing a BD or DVD Movie, what type of BD movie and is it in the menu when the CPU usage reaches its highest, do you have Windows Aero enabled? We need more information to be able to test and compare.
Here are my System Specs:
System Type: Desktop
O/S: Windows 7 32-bit (Aero enabled)
Processor: Intel Core 2 Quad Q9400 2.66 GHz
Memory: 4096 MB
Graphics: ATI Radeon HD 4850 - 07/06/2010 - 8.753.0.0
Processes: 50 (WinDVD Pro 2010 Running)
WinDVD: 10.0.5.544
- Use Hardware Decode Acceleration: Enabled - ATI Radeon
- Allow WinDVD to Check if Blu-ray is supported in the Windows Aero environment (Windows 7 Only) - enabled
WinDVD CPU Usage:
Movie: James Bond: Casino Royal
Previews: low: 01% High 09%
Menu: Low: 05% High 12%
Movie Playback: Low: 02% High: 11%
WinDVD Memory: Maxed out at 250 MB
