Video Studio Pro X3 sync problem
ixi
motherboard: intel pentium 4
processor: core 2 duo
ram: 2GB
Video Card: Intel ICH10
Hard_Drive_Capacity: 580GB
Post by ixi »
I am using Video Studio Pro X3 and have installed the patches.
Created video and plays perfectly in project mode, but when i go to share video and create a video file the video file it creates has much of the audio and video out of sync. Thi shappens no matter what type of video file i save it as. I have also tried turning smart render off and still the same problem.
Below are the video file types that make up my project
File Format: PAL HDMV
Video Type: H.264 Video, Upper Field First
Video Attributes: 24 bits, 1440 x 1080, 16:9
Frame Rate: 25 frames.sec
Data Rate: Variable bit rate (max 16000kps)
Audio attributes: 48000 Hz
Audio bit rate: 448 kps
Re: Video Studio Pro X3 sync problem
Post by Trevor Andrew »
And welcome to the forum
Although I don’t use High Definition video I am aware of some problems when rendering and using Smart Render.
Uncheck this from the Options button from the “create video file” window.
worth a try
Trevor:
That being said, I am rather puzzled by ixi's profile. He says that his motherboard is a Pentium 4, but that his processor (CPU) is a Core 2 Duo.... Obviously, one of these is wrong. And I am wondering if indeed he has a Pentium 4 CPU... If so, then it would obviously be vastly under-resourced to be able to edit AVCHD, which is what he is doing. And even if indeed he has a Core 2 Duo CPU (with an otherwise unknown motherboard), then if that too is not particularly a powerful CPU, he could still have similar problems...
ixi
ram: 2GB
Post by ixi »
i have narrowed the problem down to certain files within the project. The common trend in all the files is that they have been shortened while in the project by using the black arrows to pinpoint the exact portion of the clip i wanted to use, so while it plays flawlessly in project mode it uses a small part of the file when converting that does not appear in project mode.
I had edited this way with Ulead 10 without problems but this makes me think that of editing small clips within a project cannot be done in pro x3.
ixi
ram: 2GB
Post by ixi »
also clips which have had their playback speed altered
Post by Black Lab »
If you could clear up Ken's questions that would be helpful.
ixi
ram: 2GB
Post by ixi »
3.07 gigahertz Intel Core2 Duo
Board: ASUSTeK Computer INC. P5P43TD Rev X.0x
Accolades
motherboard: Gigabyte GA-EX58-UD4
processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
ram: 12 GB DDR3
Video Card: Nvidia GeForce GTX 295
sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
Hard_Drive_Capacity: 4TB +
Post by Accolades »
Just a stab in the dark here.
I use FRAPS to capture in-game video/audio and had a similar issuew with out of sync Audio.
I changed the pc audio setting to 44100Mhz instead of 48000. FIXED!
May be worth a look at?
May be that your PC is set to play audio at 44... and you are trying to generate a file with Audio at 48... ?
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
